11-03-2011
Morgan 33 O.I. Perryville
Right about now I would love to see weather warm enough for gators. We had a couple inches of snow here last week. Temperatures climbed back into the low 60s today, but nights are downright cold.
I had the deck core drilled and filled this past spring, and I've been checking it every couple weeks since for water intrusion, but so far no moisture readings on the hydro-meter. Maybe I'm one of the lucky ones.
Thanks for the lift point tips--I'll be sure to pass them on to the guy running the travel lift. The life is rated at 30,000 pounds, and from what I've been able to determine, the boat tips the scales as 12,500 pounds. Inside the anchor locker there's a plate that says 12,000 so I guess the 30,000-pound lift should be adequate.
Thanks again,
Gary
