11-06-2011
Originally Posted by miketucker
Hi PCP,
I think I understand the source of your confusion. I assume what you're doing is looking at the TRUE wind side of the plot, following the 8kt wind curve to, say, 45 degrees, and seeing that the boat will go 6.5 knots. Then you look at the APPARENT wind side of the plot, follow the 8kt wind curve to the same 45 degrees, and notice that the boat speed is 7.5 knots. So it seems that, as you said, the boat is going faster in 8kts apparent wind than 8kts true wind. That seems counter intuitive, for the reasons you have explained.
The problem with this comparison is that the angles on the TRUE wind side of the plot are angles relative to the TRUE wind, while the angles on the APPARENT wind side of the plot are angles relative to the APPARENT wind. Thus a course of 45 degrees to the TRUE wind is NOT the same as a course of 45 degrees to the APPARENT wind. You're comparing apples to oranges.
The two sides of the plot are showing the same information, just in different frames of reference. There is no conflict (assuming the plot is accurate of course).
Does that answer your question, or have I misinterpreted the issue you're having?
Mike
Thanks Mike. I guess you are right. To a 45º angle of true wind will correspond probably something like a 35º of apparent wind. As you say two completely different reference systems.
I was just thinking about wind speed, apparent and true, forgetting that the angle is also different
After having seen two Polars with bigger speeds on the apparent wind I knew it was my fault and that I was missing something but I could not figure what. Must be getting old
Thanks again,
