Repair Bottom? - Page 2 - SailNet Community
post #11 of 21 Old 11-18-2011 Thread Starter
John
ImASonOfaSailor's Avatar
Send a message via AIM to ImASonOfaSailor Send a message via MSN to ImASonOfaSailor Send a message via Yahoo to ImASonOfaSailor Send a message via Skype™ to ImASonOfaSailor
Yes i have done drywall work and have patched holes, i dont feel i can let this go to me its bad! i dont think its ever been done on this boat! I will look into this further what type of chemical is in this bubble to hurt you? Thanks Kindsail I will check back here for your post!
CaptainJp3
Reynolds 21
licensed OUPV/6-pack
Great Lake Erie, Marine State Park
"""Here's a toast to you on the coast and the sailors out at sea Drink your ales, hoist your sails Ride the windssssssssss and think of me,,,,,,,,,, 'cause Oh I wish I was there tonight"""
ImASonOfaSailor is offline
post #12 of 21 Old 11-18-2011
celenoglu's Avatar
Pthtallic acid forms inside the blisters. In case you leave to dry, water will evoporate leaving the acid behind which will cause blisters later. Afcids are generally not good for the skin and eyes are more sensitive. Use protective measures.
celenoglu is offline
post #13 of 21 Old 11-18-2011
tommays's Avatar
To me it looks like a bunch of tiny ones that have had other repairs
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 21 Old 11-18-2011
The larger spots look delamination has occurred .If so I'd grind it out wash and dry and lay in some epoxy with filler and fabric. Good enough is good enough. You're not rebuilding a piano here. All those smaller blisters ,unsightly as they are, I'd consider cosmetic. Sail er ard and put er away wet.
Capt Len is offline
post #15 of 21 Old 11-18-2011
I'd rather be sailing....
afrinus's Avatar
Repair blisters using "Water Displacing Epoxies"
I've come across an outfit that seems to have a "better" ?? and cheaper solution than WEST.
These guys - Hull Blister Epoxy Fiberglass Boat Repair - Boat Pox - 603-435-7199 - totes a "Water Displacing Epoxy" as the basis for repairing blisters. This is a link to the company's "how to" page on repairing blisters
It certainly seems a better solution for those of us that don't have the luxury of letting a boat sit for a long time in the maintenance yard to dry out (the only boat yard that's got a yard on the lake I sail on is somewhat of a rip-off for maintenance space)
Does anyone have any experience with this or similar system. Does it make sense to just wash out the blister and then use a displacing epoxy?
"Boat-less no more...
afrinus is offline
post #16 of 21 Old 11-18-2011
I am not familiar with the construction of this boat - but from the look of these boats, they appear to be designed to dry sail.
I wouldn't do anything.
WDS123 is offline
post #17 of 21 Old 11-18-2011
Do not do anything. These blisters are merely cosmetic and once underwater you won't see them. Almost anything you might try will probably end up worse than the problem and fixes rarely work for blisters.
I regret trying to fix blisters on my boats as I now think it was wasted effort.
Frogwatch is offline
post #18 of 21 Old 11-23-2011 Thread Starter
John
http:// http://qik.com/45896796/ef346ec1
Yes if u watch the video there are alot of them and knowing it looks like it does it will bother me.. so what I am thinking of doing is taking a hull and flipping it over in my garage for winter time and fix it all but first i need to make a craddle for the hulls so it nice and comfy..
CaptainJp3
Reynolds 21
post #19 of 21 Old 11-23-2011
Okay, I understand that. However, the only solution that will work is grinding off the gelcoat, drying it out and laying new glass or vinylester. If you just fill with epoxy, you have a very high likelihood it will come back.
Jeanneau 54DS
Minnewaska is offline
post #20 of 21 Old 01-10-2012 Thread Starter
John
I used Fibre Strand from NAPA! and all wholes are filled what is the next application to use?
CaptainJp3
Reynolds 21
oar repair jasonr575 Gear & Maintenance 1 12-10-2010 08:54 AM
Buy new or repair old? trailblazer1229 Boat Review and Purchase Forum 5 08-26-2010 03:10 PM
Repair help. kdowney50 General Discussion (sailing related) 16 04-06-2010 08:12 PM
Bottom paint Blister repair my vacation with West System aibuiltpc Gear & Maintenance 6 06-04-2009 08:38 AM
jib repair rchad Gear & Maintenance 4 07-17-2007 02:17 PM
