Bascule Bridge Raised Vertical Clearance??? - Page 2 - SailNet Community
post #11 of 15 Old 11-25-2011 Thread Starter
Undadar's Avatar
Originally Posted by Capt~Sam View Post
A bascule bridge is any bridge that can be opened and is not a fixed bridge. The horizontal and verticle clearances is marked on the chart. That is if you have the correct chart for that area.
That's what I thought too and this was the reason for my confusion since the raised vertical clearance is NOT listed on the chart (see the example).
I'm not sure what NOAA's definition is of a bascule bridge (no mention in Chart #1) but every definition that I found is basically "a type of drawbridge consisting of one or two counterweighted leaves which pivot upward on a horizontal axis to allow boat traffic to pass underneath. The counterweights help balance each side of the bridge during the upward swing, which assists in the lifting motion."
All of the examples I have found have an unlimited raised vertical clearance (ignoring wires and structures other than the bridge). For planning purposes, I believe it is appropriate to assume that they have an unlimited raised vertical clearance when not listed otherwise on the chart. Obviously, that will be checked with the bridge operator prior to passing.
JD & Buddy (the ferocious feline) - Full timer out west
2005 Newmar Dutch Star 4023 | 2010 Wrangler (daJeep) |
Undadar is offline
post #12 of 15 Old 11-26-2011
denverd0n's Avatar
And those that have wires above them will note on the chart the minimum clearance under the wires.
denverd0n is offline
post #13 of 15 Old 12-11-2011
river goes up and down,it changes all the time
gaha is offline
post #14 of 15 Old 12-11-2011
I go under one all the time you call tender on channal 16 or call on phone.Or one long and the one short blast on horn
gaha is offline
post #15 of 15 Old 12-11-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
true, but bridge and overhead wire clearances are based on "Mean High Water Springs" just as charted depths are based on "Mean Low Water Springs".
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
Bridge Clearance for Ft. Myers ct Living Aboard 7 06-19-2016 10:22 AM
Bridge clearance on ICW Pamlicotraveler Cruising & Liveaboard Forum 31 09-09-2015 04:56 PM
vertical clearance myfalkor Pacific Seacraft 8 07-04-2011 02:34 PM
Understanding NOAA bridge vertical height alanr77 General Discussion (sailing related) 8 06-29-2010 08:30 PM
Rte 146 bridge clearance in Kemah TX c2cSailor General Discussion (sailing related) 3 02-21-2008 01:16 PM
