11-28-2011
Glad I found Sailnet
For the sailboat, I use an inverter and power the standard mini lights that are everywhere and cheap.
For the car, I rewired those standard 120v mini lights into 12v lights.
How to rewire? The 100 light sets are really a 2 step ladder configuration:
oooooooooooooooooooooooooooooooooooooooooooooooooo
where "o" is a light with short wires between them, and "|" is a power wire. ("." is nothing, multiple spaces don't show up well on forums/web pages.) It does't look like this normally because one side of the ladder is shifted up dramatically, so it looks like there are 3 wires.
By connecting every 5 lights to the opposite side of the ladder, you make a 12v set. To do this, after every 5 lights, carefully strip a bare spot on the wire, carefully strip a bare spot on the latter vertical, twist the bare spots around each other, and wrap with electrical tape. Be careful when stripping a bare spot on the wires; do not actually cut any wires.
Make sure you cut the 120v plug/socket off the ends, first thing, so you don't mistake this set for a house set.
You may have to cut that last series of 5 lights to connect them to the opposite ladder, to finish off the process. Or keep them as dead lights, I don't recall what I did; it's been awhile.
Conceptually, you want it to look like this (remember there are no long wires, I'm just showing how they are twisted together):
Note the right side lights need to be connected to the opposite rung in 2 places) to make those lights work. Or you could cut them out of the circuit altogether (much easier).
The new string of lights will have almost all the length of the original lights, and you can't tell the difference between then, the modifications are that good (and simple).
Straightening out the verticals on the ladder, it looks like this.
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
ooooo
Then connect to 12v. I found no problem using this at charging voltages (13+ volts) versus actual 12v battery voltages. If anything, I found them to be a bit dim/yellow at lower voltages. Next time I do this, I may experiment with using 4 lights on each "step" of the ladder instead of 5. The lights may not last longer, but they will be brighter.
Regards,
Brad
