Old 11-30-2011
Rustyf is an unknown quantity at this point
Triple Spreader Mast
Originally posted in the wrong forum. Sorry
I understand that a triple spreader mast requires a great deal more effort and skill to tune than a double spreader and offers no advantages for a 36 foot coastal cruiser. Appreciate some comments on this.
Thanks.
Old 11-30-2011
WDS123 is on a distinguished road
Define great deal of effort
Old 11-30-2011
I deleted the other thread for you....
Whether or not a triple spreader rig offers you an advantage or not depends on what you're after.... and on the boat in question.
Generally triple spreader rigs are a smaller mast section for less windage, less weight aloft and less heeling moment. They also allow a narrower spreader width and therefore tighter sheeting angles and theoretically improved pointing. But the rest of the boat and rig have to be designed with all that in mind.
Certainly a double spreader or even single spreader rig (up to a point) can be made as strong, but at a possibly considerable weight penalty. On certain boats it would not be an issue.. on others it might change it's performance and behaviour quite a bit.
Putting a triple spreader rig on a Westsail 32 or even a Catalina 36 might not prove worthwhile... it's actually quite rare to see a triple spreader rig on a boat that wasn't performance-oriented (read at least racer/cruiser if not outright racer) in the first place.
So - any advantage for your typical 36 ft coastal cruiser? Likely not.... have you seen one so equipped?
1984 Fast/Nicholson 345
Old 11-30-2011
Thanks this has been helpful. The particular boat is a C&C 110.
Old 11-30-2011
Originally Posted by Rustyf View Post
.... The particular boat is a C&C 110.
There you go.... RACER/cruiser.....
Old 12-01-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
O totaly agree with the comments of Faster. One of the Savres....Sabre 40...another racer crusier has a triple spreader also I beleive
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Strange thing on my mast spreader aaronwindward Gear & Maintenance 6 02-28-2011 12:15 AM
Mast, spreader, shroud design, help Talisman66 Gear & Maintenance 1 11-23-2008 03:41 AM
Triple Spreader Shroud Tension Mike36 Gear & Maintenance 12 08-08-2008 11:08 AM
spreader/mast rake question Gorlog Gear & Maintenance 2 04-27-2007 01:30 PM
