12-02-2011
Super Moderator
If you dopn't plan to race I would agree with the suggestion that you buy a 135% or so. I would suggest that you consider buying 135 or so in a higher tech fiber (i.e. kevlar) that is cut just slightly fuller than a dacron #2 would be cut. This will give you better performance at the light air end of the wind range and will hold its shape better at the upper end if the wind range. It will also be a more durable sail overall. The local race fleet has gone to Kevlar genoas as a cost savings measure. Even though kevlar is a little more expensive( Not as bad as it used to be if you go with panel construction) kevlar sails just plain keep thier shape a lot longer. The local Catalina 27 race boats tend to have a #2 genoa which would probably be the hot ticket.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
