Old 12-04-2011
Rockter will become famous soon enough
Wind Speed Anemometer placement
I own a Union Polaris 36 and I wanted to fit a wind speed and direction indicator. I really cannot face the prospect of a masthead mounting. Instead I have a tall radar pole at the stern that might be high enough to give me some meaningful readings.
I attach a wee picture.
I plan on using a wee side arm to the pole, then raising the spinning impeller above the level of the radar dome.
Later, I can mount it to the mast-head, the next time I drop the mast, and that isn't planned for some time.
I trust that the stern arrangement willl mean that I will get some corrupted readings due to windage over the sails, but what do you think?
Thanks...
Rockter
For some reason, the picture will not attach. Sorry.
Old 12-04-2011
celenoglu's Avatar
celenoglu is on a distinguished road
The speed will not be correct, because it should be the speed 10 meters above sea level. The direction will be the direction of the sails not the wind. The only proper position is top of the mast.
Old 12-04-2011
Unfortunately that's true... you'll be in the wind spoil of the rig, and too close to the surface for the indication to be of much use..
Rather than spend any money on that particular installation, how about hiring someone to go up and do it properly in the first place? Or a friend/marina hand that can do it reasonable?
1984 Fast/Nicholson 345
Old 12-04-2011
celenoglu :
Yea, I know that you are right, deep down.
Are they ever seen anywhere but at the masthead?
It is so difficult to maintain them up there, and my bosun's chair does not lift me high enough to drill the mast top for such a fitment.
I will have to wait for the mast to be dropped next time.
Thanks.
Rockter.
Old 12-04-2011
Faster :
Thanks.
I could only use one of those masthead wireless systems, could I?
They are called Tictack, or something like that.
I cannot thread a conductor down the mast with the mast stepped.
Rockter.
Old 12-04-2011
Minnewaska will become famous soon enough
Agreed, totally corrupted readings when under way, so what's the point of having it. I would just as well tie some yard to the shrouds, if you need a short term solution.
You don't have to drop the mast. Get a bosuns chair. Edit: I see you posted about your chair while I was typing. There are solutions to getting higher in your chair too. Maybe install step at the top, use your chair to get there. Would be handy.
Jeanneau 54DS
Old 12-04-2011
The Bosun's chair does not allow me to get my hands high enough to get the drill perpendicular to the mast top surface.
I don't have mast steps.
I guess I will have to wait, or someone is going to kill themselves dropping 45 ft, or so.
Rockter.
Old 12-04-2011
There are solutions to getting higher in the chair. Install one step on mast. Hang a step from the spin block. Use those webbing step, cant think of their name. All versions allow you to get there in the chair and use the step at top. Good luck.
Jeanneau 54DS
Old 12-04-2011
Would one of these help?
ATN Sailing Gear- Mastclimber | Sailing Equipment
The wireless systems are very interesting concepts.. it would be nice to know how often the batteries would need replacing... although I think they are also solar powered.
Pricey, though.
Old 12-04-2011
Faster :
Thanks.
That foot-strap system looks ideal. Rather pricey though, for such infrequent use. I will look at it. Thanks.
I have my Windex up there, so I have some directional feedback.
It would be nice to have the windspeed also, methinks.
Rockter.
Wind Generator placement ??? SimonV Gear & Maintenance 10 10-16-2010 01:26 PM
new wind/speed/log instruments genieskip Gear & Maintenance 3 02-03-2010 03:58 PM
KVH Wind Speed paulsilva General Discussion (sailing related) 3 08-15-2008 04:56 PM
wind point / wind speed bkw Learning to Sail 4 09-11-2006 03:01 PM
Wind Speed fishclan Seamanship 4 02-01-2002 12:09 PM
