Like Tree1Likes
Old 12-05-2011
businessonly805 is on a distinguished road
want to live-aboard, but how do i repair?
i was wondering if anyone knew how live-aboarders go about repairing the bottom of their boat or painting it? do you go on craigslist and look for someone with a truck to haul your boat out of the water? i heard that there are cranes to lift the boats out of the water, but then what, do you need a truck after they lift it out for you? or do they place the boat somewhere where you can work on it or where they can work on it? im talking about a 25-30 foot sailboat btw. Also, if they place the boat somewhere, i can imagine they charge per day to place your boat somewhere on their property? how does this all work? i wont have any vehicle if i am going to liveaboard, so any help would be appreciated.
Old 12-05-2011
CorvetteGuy's Avatar
72 C&C Corvette
CorvetteGuy is on a distinguished road
some marina's have a travel lift which will haul your boat and locate it in a boat yard where work can be done and possibly still live aboard it while the work is in process, depending on the marinas policies. A couple hundred for haul and the same for launch. Cranes charge a considerable amount more as the must travel to and from and set up. Good luck
Old 12-05-2011
Minnewaska will become famous soon enough
I've been at marinas with and without travel lifts. I much prefer knowing that I can be hauled for repair if necessary. Props, cutlass bearings, thru hulls, bottom paints, stuffing boxes, etc, etc.
It's becoming harder around my parts to find a yard that will let you do any of your own work that creates an environmental issue, such as painting. Harder still that would let you live aboard on the hard.
There are usually two rates. One for a quick haul, where you are pulled out and stay in the slings on the travel lift, do you repair and are dropped back in on the same day. Some try to get hauled last on a Saturday afternoon, so they get all day Sunday before relaunching on Mon. Many yards have a safety problem with this. The other rate is for a maintenance haul, which puts the boat onto stands and then comes back to pick it off and relaunch when the work is done. The later being much more expensive, as it's essentially twice the work.
Jeanneau 54DS
Old 12-05-2011
my900ss is on a distinguished road
Not sure where you live although there is most likely a hint in your screen name I am missing. I know of a Boat Yard in Richmond, CA that will haul the boat, put it on stands for you and let you work on it. I am not sure about living aboard while on the hard as I had no reason to ask.
Old 12-05-2011
capttb is on a distinguished road
You only need to haul out for 3 or 4 days every 3 years for paint in So. Calif, usually any repairs can be acomplished at the same time.
"Democracy is two wolves and a lamb deciding what to have for lunch, Liberty is a well armed lamb contesting the decision."
Old 12-05-2011
peterchech is on a distinguished road
I have several friends living in their boats while doing major renovations on the hard. If it is a liveaboard marina, it is very likely you can live on your boat while it is out of the water. These friends have been living for months in the boatyard. The problem, as pointed out above, is finding a liveaboard friendly marina that lets you do your own bottom paint.
Old 12-05-2011
well i guess if they d most of the work, then it does seem doable...and if its only like once every 3 years down around so cal, then better yet. thanks for the responses you guys.....by the way, if i get a 25 foot with a removable keel, would it be cheaper to just hire somene off of craigslist who knows what they are doing, to do the repairs?
Old 12-05-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
You will probably find a 25' boat is a bit small to live aboard. Plenty have lived and cruised on 25' ers, however. If you are going with a boat that small, you might be able to borrow a trailer and use a regular public boat ramp. Then you can trailer the boat anywhere to do the work. This would especially be do-able if the boat is a swing keel (as opposed to a fixed keel boat). You should also learn to do basic boat work yourself. Saves a ton of money.
Old 12-05-2011
JedNeck's Avatar
JedNeck is on a distinguished road
If you don't know what your doing, it is almost always cheaper to have it done right the first time rather than have someone else undo and redo what you tried to do.
Sign in a machine shop:
"Our rate is tripled if you attempted the work and failed."
Use a reputable contractor for repair and maintenance work, with references. Seldom is Craigslist the best place for these. It would really suck to wake up knee deep in water(or worse) because you wanted to save $50 on a thru-hull replacement.
Old 12-05-2011
If you are buying a 25 footer, you might want to look for one that has a trailer. Although, marinas may charge you to store the trailer. Some don't, if you're a tenant.
That would even make it much easier to travel with the boat, as it could be repositioned with the trailer very easily. However, as mentioned, living aboard a 25 ft boat would be difficult for most.
Jeanneau 54DS
Live aboard? burty Cruising & Liveaboard Forum 0 12-02-2011 10:51 AM
How to become a live aboard? Newfound13 Living Aboard 46 02-10-2011 04:55 PM
Hello, live-aboard ardoin Introduce Yourself 4 03-26-2008 09:33 PM
Please help me... re: live aboard KainX General Discussion (sailing related) 18 08-20-2003 11:51 AM
used live aboard anneminix Boat Review and Purchase Forum 0 02-02-2003 06:26 PM
