12-06-2011
Originally Posted by Faster
The current breed of beamy ocean racers often do sit happily upside down, most especially if they happen to lose the keel bulb... There are some images around, Tony Bullimore for one, where he's clinging to the keel fin on a seemingly very stable upside down boat. Multis, too, are happiest that way.
But then again not many of us sail those types of boats....
Rambler is a good example of this from the recent Fastnet.
If the keel falls off I think you have bigger problems than just remaining turtled. However, the types of racing boats which are most likely to have keel issues, flush decks and super-wide planing arses are also built very light, usually foam cored. So without their keels they are likely to remain afloat like a liferaft. Kind of like a multi.
If something like a canting keeled mini 650 turtles, if the keel is canted this may help get the boat back on its side at least. However the flush deck, and relatively low ballast to displacement ratio might make recovery from turtle much less likely, even with wave action, than recovery on your standard cruiser.
I often wonder about what you do if you are in the cockpit when the boat rolls. If you are tied in (you should be), you may be held under for some time before the boat comes back up especially if sheets are not released in time or if wave/wind action coincidentally holds the boat inverted longer than would be expected. If you cut away from the tether to get to the other side of the boat, you risk being separated and lost at sea. Webb Chiles talks about being rolled twice in the southern ocean on one of the "furled sails" podcasts, but he was in the cabin both times and the boat came right back up. I think I would be tempted to throw out a sea anchor and hide below if the going got really rough, but that isn't always an option and often it is a rogue wave that breaks unexpectedly which rolls the boat.
