I have a new blog entry about YONI, one of my more interesting projects - Page 3 - SailNet Community
 2Likes
post #21 of 22 Old 12-10-2011
Geoff54's Avatar
Nice looking Yacht and really interesting to read the story behind it.
I hope I’m not asking too much - I have a simple question which may be require too long or complicated an answer for here - I won’t be offended if you tell me to go and read up on design principles (would you mind pointing me in the right direction?). Also, I believe that “Limit of Positive Stability” is exactly the same as “Angle of Vanishing Stability” i.e. the zero axis when the Center of Gravity is directly above the Center of Buoyancy, before which (in the absence of any other forces), a boat will right and beyond which it will continue to invert. If I’m wrong, that might explain things, otherwise…
I was surprised to read that that achieving a Limit of Positive Stability of 135 degrees “can be a challenge for some cruising boats”. I always assumed that, within some reasonable limit, achieving a higher AVS was mostly a matter of lowering the C of G by using a deeper and/or heavier keel. I took a quick look at the R.Y.A. Stability List and while there are many boats with numbers under 135, there are quite a few respected cruising yachts with numbers significantly above that (examples include Nordship 40DS – 140, Island Packet 485 – 143, Swan 602 – 153, Sweden Yachts 42 – 156, Vancouver 34 – 166). There are even a few with an AVS of 180, which I didn’t realize was possible – a cork ball with a six inch nail stuck in it, maybe.
I always thought that lower AVS was a compromise because of some combination of cost, desire to keep the overall displacement down or sacrificed because of form stability (cue – wide butt discussion).
I assume I’m missing something but I’m not quite sure what.
Thanks
Geoff
Geoff54 is offline
post #22 of 22 Old 12-10-2011 Thread Starter
grumpy old man
tdw:
Knee is much better thanks.
Bob's Blog ....
bobperry is offline
I have a new blog entry on rudders bobperry General Discussion (sailing related) 48 11-12-2011 06:56 PM
Check out my new blog entry bobperry General Discussion (sailing related) 2 10-29-2011 08:51 PM
Interesting Blog on buying and restoring a sailboat mkrautha Boat Review and Purchase Forum 19 01-06-2010 12:45 PM
New blog entry, including lots of pics and a BBQ pic for CD! labatt General Discussion (sailing related) 7 04-17-2009 09:14 PM
New blog entry - Charleston to Vero Beach labatt General Discussion (sailing related) 4 01-31-2009 11:55 PM
