Cast Iron Keel Renovation - WS Epoxy vs. Barrier Coat first sealing layer - Page 2 - SailNet Community
post #11 of 11 Old 12-13-2011
For'n aft'r
Another vote for interprotect 2000. The poster who mentioned soap and water was referring to removing analine blush from the surface of fresh epoxy between coats.Not neccessary with Interprotect since one applies it over a semi-cured previous layer. Good suggestions from SloopjohnB, but I had good results without sandblasting.
Ocarina II is offline
Epoxy Barrier coat stevemorrell Gear & Maintenance 7 01-15-2016 01:32 PM
Cast Iron Keel neoxaero Gear & Maintenance 7 11-30-2010 03:30 PM
Cracked cast iron Keel arosental Gear & Maintenance 5 01-20-2010 01:55 PM
Cast Iron Keel rust bareboatskipper Beneteau 5 06-05-2008 11:05 AM
cast iron keel coating jritchie Gear & Maintenance 17 03-03-2001 07:24 AM
