Fuel Consumption - Page 2 - SailNet Community
post #11 of 18 Old 12-23-2011
tommays's Avatar
I run my A4 at 1500 RPM as it just stuffs the stern at more RPM to go a tiny bit faster while i have not done exact it is way under 1 GPH
To go from 5.5 to 6.5 knots most likely doubles the fuel burn as thats the point were it stuffs the stern with a 24' W/L
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #12 of 18 Old 12-24-2011
I use a dipstick, with a volume conversion chart.
I don't have a fuel guage.
Rockter is offline
post #13 of 18 Old 12-24-2011
addict's Avatar
Send a message via MSN to addict
My fuel gauge is an old batten. I normally watch my hours and start checking around 20-25 hours which is about half a tank. My old 2gm burns around 1.25-1.3 liters per hour @ 2400-2600 rpm.
addict is offline
post #14 of 18 Old 12-24-2011
JimsCAL's Avatar
I agree that Boasun's SFC estimate of 0.6 lb/hp-hr is a bit high. I would estimate something like 0.45 to 0.50 is closer. But the big thing to keep in mind is that you are typically running at FAR less than rated power. Power requirements vary approximately with the cube for a displacement hull. So reduce the speed by 20% and you cut the power (and fuel consumption) by half (0.8x0.8x0.8=0.512).
JimsCAL is online now
post #15 of 18 Old 12-24-2011
cruising all I can
32' boat w/a 4ft draft full keel 10' beem 35 hp. kubota 4cyl w/ a hurth 125 2.73to1 ratio w/ a 19r11 three blade prop. gross weight 13-14000# burning less than 1/2 gal. an hour on flat water.
I think there are alot of factors that will influence the amount of fuel usage beyond just the engine size and operating speed.
even the "freshness " of the bottom job would effect it.
joethecobbler is offline
post #16 of 18 Old 12-25-2011
Moyer Marine sent out an email not long ago about a nice little upgrade for our beloved Atomic 4s. How about a new carburetor jet that reduces fuel consumption to 1/2 to 2/3 a gallon per hour! I haven't had the chance to follow up on this yet, but I'm looking forward to it.
SkywalkerII is offline
post #17 of 18 Old 12-25-2011
LakeSuperiorGeezer's Avatar
Lean running engine
If engine runs lean, could burn exhaust valves. I would leave as is.
LakeSuperiorGeezer is offline
post #18 of 18 Old 12-25-2011
travlin-easy's Avatar
Just about everyone I know that uses an A4 also uses a product called Marvel Mystery Oil, which is a top-cylinder lubricant that has been around for more than a half-century. It pretty much prevents valve burning, while at the same time aid in seating and sealing the valve and valve seals. You can still buy this product in most automotive stores and it is added to both the fuel and crankcase. I'm convinced that this product alone is responsible for keeping most A4s in good running condition, and at the same time helps boost fuel economy.
Cheers,
Gary
travlin-easy is offline
fuel consumption gas vs diesel jklewissf Gear & Maintenance 25 05-11-2013 07:28 PM
Fuel consumption question tireman Gear & Maintenance 15 05-18-2011 12:18 PM
Fuel Consumption SimonV General Discussion (sailing related) 10 02-14-2007 12:28 PM
Excessive Fuel Consumption pirateofcapeann Gear & Maintenance 8 01-22-2007 11:28 AM
fuel consumption Darco1 Gear & Maintenance 1 04-12-2005 01:15 PM
