Originally Posted by PaulinVictoria
The Alado is an interesting unit Gary, I'm considering one, would be very happy to hear your experience of it over the past 5 years
The Alado system is among the least expensive and best constructed roller furling systems I've seen. The design is such that it distributes pressure evenly on the forestay, yet after five years of intense usage there was no noticeable wear on the forestay.
The aluminum foils are designed to overlap, and there are no pins to worry about loosing. The drum is constructed from heavy-gauge aluminum, and rides on a special bearing that doesn't create wear on the forestay. The drum is quite large therefore decreasing the amount of pressure needed to furl the system.
A couple years ago Practical Sailor magazine evaluated roller furlers and placed this one right the top of the list. After installing my Alado system, several other boaters in the marina saw it in action, asked where I purchased it, and with a few months, they too installed the Alado.
Installation is very easy, can be accomplished by one person in less than 30 minutes, but it's a bit easier if you have a second person to help install the drum.
The Alado system uses its own halyard, and it can be rigged for using a pair of headsails on the same system. I've never done this, but there are folks that have and reported excellent results.
You can download complete installation instructions from
ALADO - Furler and Roller - main page
Hope this helps,
Gary
