Like Tree3Likes
Old 12-27-2011
adamsj23 is on a distinguished road
recycling an internal lead keel
How hard or reasonable is it to get the lead out of a Bahamas islander 30 keel for recycling?
Old 12-27-2011
boatpoker's Avatar
surveyor
boatpoker is on a distinguished road
you can do it with a chainsaw in about three days .... or about 20 minutes if you take her out of the water first.
HDChopper likes this.
Dirt People Scare me
Old 12-27-2011
You can do it in the water??? Huh?? I was actually worried I couldn't get it down to clean lead.
Old 12-27-2011
Has anyone tried to recycle a keel?
Old 12-27-2011
Minnewaska will become famous soon enough
Understand there is probably a degree of suspicion, since lead is occasionally poached.
Jeanneau 54DS
Old 12-27-2011
hellosailor's Avatar
Draw a dotted line around the keel stub. Cut any nuts off the keel bolts with a Sawzall if they won't unbolt, then cut along the dotted line.
Now you just have to pick it up and carry it to the scrap yard.
Back a pickup truck under the keel before you cut it loose, get Dodge or Chevy to sponsor the commercial. (G)
bljones and StormBay like this.
Old 12-27-2011
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
You are a bad man, HS.
It's 5 o'clock somewhere:
Old 12-27-2011
tommays's Avatar
Around here it would cost far more to landfill the hull than the lead is worth which is why they sit around forever
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 12-28-2011
pereubu is on a distinguished road
Recycled a keel in Texas off 25' Cal and received $1300. Watch the prices. I would think it's worth it. Be sure you can haul it. Good luck!
Old 12-28-2011
There was a boat that was beached during hurricane Earl in 2010 that I recall was found sans its keel, which was presumably poached for scrap.
Jeanneau 54DS
external lead keel bigsarg1 Boat Review and Purchase Forum 7 06-20-2011 08:30 PM
Will a lead keel rust? nolesailor Gear & Maintenance 6 03-29-2010 11:02 AM
can you tell if keel is iron or lead jenweberfuller Boat Review and Purchase Forum 6 10-02-2006 10:14 PM
Lead keel coating Soutie Gear & Maintenance 15 08-01-2006 11:31 PM
Steel Keel vs.Lead Keel Rondolais Chartering 1 12-24-2003 03:28 AM
