I am fixing my hull it is like little smiley faces with a brown mouths i have just been finish the crack by cracking them with a razorblades but my question is it doesn’t seem like a bad job but a lot of like little holes now.. SO what is the best stuff to use that might fill it in one coating? my brother said something like Duro Glass i cant really find it online he said NAPA but i was wondering like that is a AUTO store... Any help would be greatly appreciated! thanks
CaptainJp3
licensed OUPV/6-pack
Great Lake Erie, Marine State Park
"""Here's a toast to you on the coast and the sailors out at sea Drink your ales, hoist your sails Ride the windssssssssss and think of me,,,,,,,,,, 'cause Oh I wish I was there tonight"""
Without pictures its a bit hard to understand the size of each defect and the scope of the issue as in is it 20 or in my case 10,000
The big issue is having it come out again with use as boats are always flexing and expanding and contracting with the weather
I used system3 epoxy filler as most of the stuff the PO had done was popping out again
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The usual fix for gelcoat cracks is to "vee" out the crack with something like a Dremel tool and then fill with new gelcoat. If its not pure while, you will need to tint it.
CaptainJp3
CaptainJp3
Reason: embedded vid
ok so #105 is all i need to fill in my cavities with or is there more supplies to buy do i mix the harder too is that what 105/205 means ?
thanks
CaptainJp3
The article says to use hardener if you are in a hurry. If you have time to let the epoxy cure on it's own, according to the article, you don't need to use it. I have a few spots on my boat to do the same thing to once it gets warmed up.
__________________ Umquam Porro
S/V Papillon 1977 O' Day 25
One is a 'fast' hardener intended to be used at lower temperatures.. at normal temperatures it would kick too fast. The 105 is the resin, the 205 or 206 are the different catalysts. You cannot use the resin without a catalyst.
For jobs like this it's important to use the thickeners described to avoid sag.. it also eases sanding and fairing later on.
Looks like the OP's catamaran had some serious voids in the initial construction and they are all coming to roost now... best of luck, it will be a time consuming job - with the finishing part the hardest.
__________________ ".. there is much you could do at sea with common sense.. and very little you could do without it.."
BTW - there are so many 'white' gel coats, depending on manufacturer, and even if you have a wet match it may not cure the same shade. That is where the seasoned expert comes in.
