-   -   Asym. spinnaker measurement help needed (http://www.sailnet.com/forums/general-discussion-sailing-related/82446-asym-spinnaker-measurement-help-needed.html)
sailndoug 01-06-2012 10:28 AM
So the question is; how long should the luff be on an asymetrical spinnaker if my present genoa luff is 49'? Looking for a downwind solution but don't know nuttin' bout no spinnakers. Thanks!
Faster 01-06-2012 12:09 PM
Suggest you go to FX sails site and fill out the estimate form for your boat.. I think you'll end up with sail dimensions from that.
DonScribner 01-06-2012 01:27 PM
SAILRITE has a similar program. I'd do both and compare.
sailingfool 01-06-2012 02:29 PM
54 Attachment(s)
If you measure off your genoa, you will end up with a cruising spinnaker...better than a white sail but not a whole lot better. Its primarily a question of sail area. If you want some performance, you should consider a symmetric, or an asymmetric with a bow sprite, both would offer the large sail area needed to make off wind sail as much fun as upwind sailing. A asym is easier to handle.
zz4gta 01-06-2012 03:03 PM
You want it longer. Probably (guessing here) 51-54'. The luff of a jib is almost a straight line. The luff of a chute is going to have a pretty big curve in it.
