01-09-2012
Originally Posted by Barquito
Is there anything wrong with just leaving it raw fiberglass? Once it is cleaned and blasted with chlorine to kill everything, is epoxy paint any better?
Raw fiberglass, including gelcoat, etc. contains either styrene / polyester which never fully 'cures' thus continually emits unbound styrene monomer, etc. into the water; or, epoxy unless a low amine epoxy will also emit high amine levels into the water .... both of these species of chemical fragments are linked to quite severe pathology on long term and additive exposure. You definitely dont want to be drinking water, or brushing your teeth, washing your dishes, or even taking a shower with water from a 'raw' fiberglass tank.
With water or food, etc. you really need to use NSF or FDA rated materials .... and that includes the hose that you use to fill such tanks.
Sanitization is a whole 'nuther' story but suffice it so state that the tank internals must be mechanically cleaned to a high degree before sanitization ... or the sanitization will be incomplete and very short in time before the microorganisms begin to 'flourish'. Surface 'roughness' vastly retards the efficacy of sanitization.
