The final solution - what I came up with regarding auxiliary propulsion (pic heavy) - Page 2 - SailNet Community
 22Likes
post #11 of 52 Old 01-10-2012
Chastened
Ajax_MD's Avatar
I can't see the photos where I am, (yet) but it sounds like a good idea. I think you should try to source a two-stroke 5hp engine. The weight would be comparable, and you'll have more HP.
If you coordinate with winds and currents, hopefully this can get you through those narrow, unsailable areas of the ICW. I'm glad you came up with some kind of emergency propulsion.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #12 of 52 Old 01-10-2012
tommays's Avatar
NOT that it does not take HP to move a boat BUT IMHP I think there is a massive misunderstanding of just how bad a standard prop is
Because 4HP moved the 8000# Cal 29 at 4.5 knots and while the now healthy A4 will go 6.5 + the stern sinks above 5.5 knots
The biggect issue was NOT sinking the motor while crossing some BIG barge wakes in NYC
They use pretty much the same system on Jboats Up to the J29 MHOB
chrisncate likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 52 Old 01-10-2012
travlin-easy's Avatar
Nice job, Chris. Hope meet up with you can Cate again this spring.
Gary
travlin-easy is offline
post #14 of 52 Old 01-10-2012
Chris,
Wondering what effect taking out maybe 300 to 400 pounds from way down low and adding 50 or so pounds way back and up high might have on the sailing characteristics of your boat? Maybe making it a bit tender? Seems like a big change in the overall design function? If you can find someone that has made the same change it would be interesting.
Dabnis
dabnis is offline
post #15 of 52 Old 01-10-2012
Chastened
Ajax_MD's Avatar
Originally Posted by dabnis View Post
Chris,
Dabnis
The void where the engine was, probably will not remain empty. He'll load it with gear which will probably offset the missing weight somewhat.
Now that I'm home, the gear looks solid, and well-made. I really encourage you to look for a 5 - 8 hp TWO-STROKE outboard. It'll be very light and give you a better push against an adverse current. If you're going for a 4-stroke engine, then yeah, 4hp is probably your weight limit.
Ajax_MD is offline
post #16 of 52 Old 01-10-2012
Chris, that's a good idea... but like most, it's not new. We had a boat built in 1982 with exactly that setup - a 24 foot dayracer that raced one-design with the motor below on the cabin sole. We had the exact same type of bracket that accepted the more standard lighter duty spring loaded OB bracket.
We left the motor on the bracket and lifted the whole assembly off the slider just as you plan to do.. there was a keeper pin to prevent the motor/mount from 'hopping' off the transom on a big wave.
Nevertheless, good thinking, and nice work - should work fine!
Faster is offline
post #17 of 52 Old 01-10-2012
Tartan 27' owner
CalebD's Avatar
Seems like an uncharacteristically pragmatic way of dealing with having no engine; carrying an engine for use 'as needed'.
I also must agree that the looks of an outboard hanging off your pretty stern overhang is anathema.
Your bracket bracket looks pretty solid too. Time will tell. If it works then you can patent it and see if it helps your cruising kitty.
For those that asked, I believe that CnC has a 30' S&S sloop, IIRC. Nice looking boat and he has really spared few details with his re-fit.
It is going to be along winter so as far as I'm concerned you can make baiting comments all winter long but in the spring you better be heading somewhere.
Everybody has one:
CalebD is offline
post #18 of 52 Old 01-10-2012
Glad I found Sailnet
Bene505's Avatar
Looks great!!
Watch out for bigger seas, where the prop might come out of the water (or the engine get submerged).
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #19 of 52 Old 01-10-2012
Chris,
OK, so noted, 50 extra gallons or so should hold you for a day or two. As said earlier a small motor is better than no motor. Hope it all works out as planned, keep us posted.
Dabnis
dabnis is offline
post #20 of 52 Old 01-10-2012 Thread Starter
You really are funny!!
chrisncate's Avatar
Thanks! You wouldn't happen to have any pics would you? I'd love to see another design on this idea.
chrisncate is offline
Electric propulsion scrumhalf Gear & Maintenance 3 05-01-2008 05:55 PM
Consensus on electric propulsion brak Gear & Maintenance 9 04-30-2008 10:42 PM
Electric Propulsion vardaman77 Gear & Maintenance 5 08-05-2007 07:09 PM
Auxiliary Power penthink Boat Review and Purchase Forum 4 08-26-2004 10:14 AM
