01-13-2012
I have motored in reverse over our neighbors "excessively hanging in the water" dock lines last year. If you don't know about it, your engine will stall and you will drift backwards... and try to gain control over your boat. Difficult to remove from the shaft and prop at that point but only damage was a loosen stuffing box. Per the Marina's mechanic, typical problem is this is cutlass bearing damage and that is about it. $30k is a ridiculous amount of damage but if the situation is right and perhaps you have collapse motor mounts or issues with your transmission, or any other poor existing condition to your drive, etc... you could make those conditions worse and cause compounding damages but really not the direct cause of the dock lines.
But on the other hand, if I was unable to control my sailboat after I stalled out and ran into a $250k boat, sure, there is a good chance you could cause $30k worth of damage... to someone else's boat.
Patrick
S2 11.0A
Chesapeake Bay, Va
