01-18-2012
Señor Member
BLJ:
Knowing that you are a kindred spirit (i.e., actively seeking out ways to pinch every penny) I'd recommend you keep it simple.
VistaPrint can set you up with 250 for $10 as long as you choose from a template that is in their data bank. 250 cards would likely serve you for as long as you either a) have the boat or b) change info on the card.
You can also do as PDQ does and print out your own -- this is what we did, and added the flexibility of changing info as needed, as well as making it a more personal and memorable card than the vanilla option like VistaPrint.
At a minimum, I'd have the boat name, crew name, and some form of contact info (cell number, e-mail address, home address or address of your mail forwarding service.)
Anything more than that starts to get excessive -- think KISS. Some cards reek of narcissism, but that usually serves as an accurate reminder of the crew in question.
Although I've seen it on some, I'd think hard about adding your MMSI to the card. If you want to share it with particularly good friends you meet along the way, you can always write it down on the card you give them.
