01-19-2012
Morgan 33 O.I. Perryville
I've only tried two sextants during the past decade, including the Davis plastic sextant sold by West Marine. The best accuracy I experienced was approximately +/- 6 miles, which would be fine in the middle of the ocean. So, if both of my GPS systems failed, and I was well offshore when the failures occurred, then the GPS would be a handy gadget to have onboard. However, I've used Loran-A, Loran-C and GPS, all since their inception, and never experienced a failure. Either I'm darned lucky, or electronic navigation systems are very reliable.
I guess from my perspective, having a good, electronic backup system is a far better investment, especially if you're not going to spend endless days and weeks offshore. However, if you are going offshore, maybe crossing the oceans, then as stated above, purchase the best sextant you can afford--it may end up being your only backup, navigational system.
Good luck on whatever you decide upon,
Gary
