Old 01-20-2012
newport1985 is on a distinguished road
rudder leak
My rudder shaft leaks when sailing on a newport 28 can someone help
Old 01-20-2012
treilley's Avatar
treilley is on a distinguished road
Probably your stuffing box. You may be able to tighten it to prevent the leaking or you may have to repack it. Only way to tell is to crawl in there and check it.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 01-20-2012
thanks
Old 01-20-2012
Sea Diamond is on a distinguished road
Don't sail on a Newport - sail on the water. n'yuk, n'yuk
Old 01-20-2012
Groan..........
1984 Fast/Nicholson 345
Old 01-20-2012
I know, I know... it really sounded funnier before I pushed the "send" button. (You know, sail IN the boat, sail ON the water. Anyway, I promise not to quit my day job.
Rudder cap stuck on rudder, how to remove? Capt. Mhack Gear & Maintenance 1 11-30-2011 11:55 AM
Leak at Rudder Stuffing Tube Eagle16 Chrysler 2 05-16-2011 09:50 PM
Leak on a 28-2 angus99 Cal 8 11-02-2010 07:17 PM
*&%&$#ing Leak! sailordave General Discussion (sailing related) 20 03-30-2010 09:18 PM
When a rudder bearing is bad, can it cause a leak? rryan14 Gear & Maintenance 5 05-19-2008 05:17 AM
