casting Bronze porthole rings - Page 2 - SailNet Community
 2Likes
post #11 of 30 Old 02-16-2013
Old as Dirt!
svHyLyte's Avatar
Re: casting Bronze porthole rings
Considering the time, expense and experience needed for the success of such an effort, you might find you are better off, and will have better results by dealing with a knowledgeable, experienced fabricator that might even have what you need off the shelf. For example, take a look at Bristol Bronze
FWIW...
svHyLyte is offline
post #12 of 30 Old 02-17-2013
hi, i agree it will be faster and probably cheaper to ask someone else to do it.
That goes for everything in a boatbuilding process .
So we rather stick to making stuff ourselves.
What we gain is tremendous amount of skills in different type of fields.
ze
sailing the farm - a sea gypsy tribe of tomorrow
davidpm likes this.
zeyang is offline
post #13 of 30 Old 02-17-2013
I agree with you there but casting is just one of those super steep learning curves. Even with more forgiving materials such as lead and aluminum there is a pretty steep curve.
CNC can be quite involved. I would start by making a paper blueprint that I would take back to my old college professor to get one of his students to translate into G code which I would then help set up and run on one of the schools CNC machines to machine the part I want. I would then either sandblast or acid etch the part to obtain the desired semi rough finish on the outside (the casted look) and then I would install the part on my boat knowing that the allow was properly mixed.
The thing most people dont know about alloys and 1960-1970's rudder shafts are an excellent example.
Stanless steel has a content of nickle in it to help keep the steel from having its normal brittle sheer characteristic (Since a lot of force is sometimes exerted on rudders) this gives the rudder shaft some spring to be able to flex and bend as opposed to twist and break.
Nickle and steel are VERY hard to get mixed evenly into a good alloy. during the 70's and prior that alloy was hand mixed and hand casted. They have lasted very well but for anyone who has had the misfortune of owning one that someone did a bad cast on the result is that the nickle content is higher and lower in different portions of the shaft, the eventual result is you trying to figure out 1. how you catch your rudder thats floating away and 2. how you are going to get back to your slip/mooring.
We should all know that portholes are one of those areas that can sink a vessel when a storm becomes bad enough that you have to close up the cabin. Not the kind of an area where I would want to risk it.
Not when I can use materials already on hand to cut machine a part where the alloy will be as close to perfect as one can humanly make it.
SirRedemption is offline
post #14 of 30 Old 02-17-2013
I might add that with the rudder shaft example
Too much nickle in the alloy and the shaft is too soft and also will leach from the inside out (nickle leached out from the inside leaving a hollow weakened alloy that eventually breaks) too little nickle and the shaft will be brittle to radial twisting forces (such as those applied on a rudder)
Metals such as Aluminum, bronze, stainless steel, brass are all very very finnicky about this.
post #15 of 30 Old 02-17-2013
tommays's Avatar
I put really expensive broken stuff back together and and the cost of the waste alone from DIY casting casting naval bronze would be
Even with aluminum its become so hard to get good castings (EPA)we just CNC it out of solid billet now
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #16 of 30 Old 02-17-2013
One of None
deniseO30's Avatar
ze
And how is the build going? Looks like you used Aluminum as "planks"?
Did a little sleuthing LOL here's the link to your build on Welding web. http://weldingweb.com/showthread.php?t=29094
and....
IMPRESSIVE PROJECT!
My last project!
deniseO30 is offline
post #17 of 30 Old 02-17-2013
Blue Horizons
Harborless's Avatar
Costs????????? APX? Very curious...
That is the most epic 60 seconds of boatbuilding ive ever seen. What a freaking sick boat. Sick!
Also, OP, you are doing rugged stuff like the person above. I dig it and more power to you. Check out the book by
Harborless is offline
post #18 of 30 Old 02-17-2013
Cost for the boat above?
Really hard to calculate. some 5000-7000 hours of work totally. 5 tonns alloy. 20 big tanks of argon. maybe around 1 ton pine totally (incl. cutoff) 6 ton scraplead. 60.000 kw electricity. some tons of food (for volunteers)
+ lot of bruises, 1 crashed skull. and lots and lots of fun and tears:-)
sofar.
ze
zeyang is offline
post #19 of 30 Old 02-17-2013
Senior Moment Member
SloopJonB's Avatar
hi, we are doing some test of trying to cast in alloy.
Its not that easy, so we need some mroe testing first. Since we need 20 of them in different size we hope it would be easier to learn to cast them than trying to get them from china. (and more fun) Probably spend another week or two shaping up the skills a little.
ze
see youtube video on the first process.
Sailing the farm - porthole casting - YouTube
I think you and Brent Swain were separated at birth.
For that ring, wouldn't it have been a whole lot easier to just cut a piece of pipe of the right size?
SloopJonB is offline
post #20 of 30 Old 02-17-2013
Yes. but it will soon be more advanced. since we need 20 pcs it will be good to find a way to cast this more or less in one piece with ears and everything.
like this.
zeyang is offline
Porthole sealing question(s) rookie00 Gear & Maintenance 9 07-03-2015 08:09 PM
DIY Porthole Gaskets ReddOne Gear & Maintenance 20 06-22-2012 04:59 PM
Red Rubber Preventer Strap with Bronze Rings in Ends yawlboy Gear & Maintenance 1 01-06-2012 01:36 PM
porthole covers charlienpam General Discussion (sailing related) 7 06-13-2010 07:38 AM
Porthole Question Alden68 General Discussion (sailing related) 2 04-28-2007 10:06 PM
