Old 01-22-2012
addict's Avatar
addict is on a distinguished road
Send a message via MSN to addict
what's involved in removing an injection pump on a yanmar 2gm?
Hi all.
Just looking for a little help on removing my injection pump.
Old 01-22-2012
sawingknots's Avatar
sawingknots is on a distinguished road
not much at all,remove the fuel lines [to the injectors and from the transfer pump],remove throttle linkage and the 2 retaining bolts,note the timing shims!
Old 01-22-2012
why are you removing it?replacing,rebuilding?if you put on a different pump it will need to be retimed using shims
Old 01-22-2012
addict's Avatar
I'm sending it out for rebuild. Sent the injectors in, they had lots of corrosion. Looks like I having governor problems with the injection pump.
This is a yanmar 2gm. Aside from the 4 nuts up top and the fuel lines I can't see anything else to remove but don't want to break anything.
My backround is with vw diesels. I don't have much background with these yanmars and up until recently haven't had to do much to mine other than service...
Old 01-22-2012
the lines are easiest to remove by using a wrench to hold and another to turn,if you arrange them fairly close together then use one hand to squeeze,i would strongly advise you to get a mechanic's manual for that engine,its been a long time since i worked on a 2gm but i'm fairly sure about the shims,it may require retiming
Old 01-22-2012
overbored's Avatar
overbored is on a distinguished road
Down load manuals for free http://www.motoren.ath.cx/menus/yanmar.php
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
Old 01-23-2012
HPLou is on a distinguished road
Send a message via AIM to HPLou
Sawingknots is correct on the use of timing shims for the reinstallation of the injection pump. A manual is a must read for this project.
Volvo Penta MD7A Injection Pump and Other Parts for sale SeaWolfe Introduce Yourself 3 07-26-2011 09:17 PM
Yanmar 2GM injection pump issue? kcford Diesel Engine Forum 10 05-03-2011 10:03 PM
Ford Lehman fuel injection pump ymerle Gear & Maintenance 0 04-26-2009 01:59 AM
Yanmar - fuel injection pump question rperret Gear & Maintenance 7 05-24-2007 10:00 AM
Probable Injection Pump failure YSE8 gsheath Gear & Maintenance 0 07-10-2006 11:45 PM
