Like Tree4Likes
Old 02-04-2012
First String
ltgoshen is on a distinguished road
I may have screwed up on my halyard
So today I went to replce SS wire to 3/8 rope to just rope. I used a small line and pulled the ss/ robe off the mast with a tag line tied on. I then tied the small tag-a-long line to the new 3/8 halyard line and sust as I got to the top of the mast the small line slipped over the shive and now is will just alomst will not move? Any Ideas short of climing the mast to un do this mess?
any help I will be greatful.
Old 02-04-2012
travlineasy's Avatar
Morgan 33 O.I. Perryville
travlineasy is on a distinguished road
Sounds like someone will be going up the mast.
Good Luck,
Gary
Old 02-04-2012
Minnewaska will become famous soon enough
Did the wire previously run over the sheave? If so, you want to go up there to replace it for rope anyway, or at least be sure it hasn't grooved and will chafe the line.
Jeanneau 54DS
Old 02-04-2012
Sounds like it's come off the sheave and is jammed in beside it.. nothing for it but a trip upstairs, if so.....
1984 Fast/Nicholson 345
Old 02-04-2012
mananamon is on a distinguished road
There are always options. If you don't want to go up the mast I suppose you could drop the mast.
Or, another option would be to talk someone else into going up the stick.
Old 02-04-2012
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
You could always tape 10 extended boat hooks together and try and push it up. sic
Looks like a trip up the mast...while you are doing it do some maintainence on lights, wind instruments, spreader boots etc. etc wheile you are up there
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 02-04-2012
First String
maintenance
Dave
I just got this boat, So I dont know what light
1) bulbs are up there
2) I'm not sure what a spreader boot is?
3) Should I do all my lines while i'm up there?
Not sure if I should be going to all 3/8 halyards lines from the SS 3/8 anyway.
I was told to use a bowline and cut the knot off each year and retie a new know each sailing season and it would be fine?
I knot know what all the lines are even for yet. There is like 6 lines,
2 which are stainles steal one foward and one aft. then maybe a spin, a jib an out haul? not sure. any thanks for the help. Lookis like I will learn how to clinb the mast.
Old 02-04-2012
If the boat is in a boat yard with a cherry picker, they will usually go up there and check everything out for under $100, including replacing light bulbs and routing the new halyard. I had this done, and for me, an old guy of 71 that really doesn't like heights, I figured it was a great deal.
Good Luck,
Gary
Old 02-05-2012
Squidd's Avatar
Tacky yet Unrefined
Squidd is on a distinguished road
And they said getting a pet monkey was a dumb idea...
They're not laughing now...
"Might as well cast off...If anything bad is gonna happen...It's gonna happen out there..."
"Captin Ron"
Old 02-05-2012
chrisncate's Avatar
Mango intolerant
chrisncate is on a distinguished road
Just get a new boat...
ltgoshen and All-in like this.
halyard shackle letting go, spinnaker halyard interference ctlow Gear & Maintenance 13 05-23-2011 10:55 AM
My boat is screwed... eherlihy Gear & Maintenance 38 05-10-2011 07:32 PM
We are so screwed knothead Off Topic 28 07-09-2010 03:46 AM
SCREWED nauticalrich General Discussion (sailing related) 9 08-26-2002 05:17 AM
