02-06-2012
Bristol 45.5 - AiniA
Bizarre does not come close, but I will play.
How about this, assuming you could make your massive stock of iPads waterproof. Since you are going to have a boat made out of costly electronic devices, might as well have the do something. Have a 'two-ply' hull of iPads mounted back to back. The other ones are set to take video of what is on the outside, ie - the water, while the images are sent to the inside screens, so you would have a lattice of the edges of the pads (I guess where you epoxy them together) with a moving image of what is outside showing inside
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
