Like Tree6Likes
  #21 (permalink)
Old 02-11-2012
jjablonowski's Avatar
jjablonowski is on a distinguished road
Like our Tiller Lock
Very quick and easy to use. Lever forward, the rudder position is locked. Lever aft, line friction relieves some tiller pressure. Lift line out, totally clear.
Joe - Catalina 25
  #22 (permalink)
Old 02-11-2012
Squidd's Avatar
Tacky yet Unrefined
Squidd is on a distinguished road
I've seen those too, and between this and the plastic "tamers"...I'm leaning towards this...
But I've seen a couple cool "rope tricks" here now too so appreciate all the options and participation...
"Might as well cast off...If anything bad is gonna happen...It's gonna happen out there..."
"Captin Ron"
  #23 (permalink)
Old 3 Weeks Ago
dfzurcher is on a distinguished road
Re: Tiller Lock
Here is something new that uses no ropes.
Tiller Brake
  #24 (permalink)
Old 3 Weeks Ago
arknoah's Avatar
s/v Ilya
arknoah is on a distinguished road
Re: Tiller Lock
Originally Posted by FoolishMuse View Post
The tiller tamer is a pain because you need to unscrew it to release. And you will have to release any time the boat gets off course.
For years I've used a rope, about 6' long, with 1' of bungee cord on either end. I clip the bungee cords to the toe rail. And then 1 or 2 wraps of the rope around the tiller tip (depending on wind strength).
The beauty of this is that it is easy to push the tiller manually if you want to. It just stretches the bungee cords. It is also instant to remove the rope if needed.
See the first section of the video at FoolishMuseSelfSteering.wmv - YouTube
This is the method I use as well (I took it from Andrew's book). I find that I can adjust the rudder either by simply moving the tiller manually or just by twisting the loops around the tiller, which gives fine adjustment in either direction.
Works like a charm and I only had to pay for the clips I use to attach the ends to cleats.
Ilya's Adventures:
____________________________
And straight on 'til morning
New tiller lock design dfzurcher Gear & Maintenance 19 3 Weeks Ago 11:46 PM
Can Anyone Identify My Tiller Lock? GloucesterTom Gear & Maintenance 3 02-06-2011 04:33 PM
Tie up tiller/lock wheel when away? Or not. CalebD General Discussion (sailing related) 23 10-11-2009 05:30 PM
Advice for repair of tiller pilot->tiller connection jgsteven Gear & Maintenance 2 09-11-2009 04:53 PM
Lock It ! Freesail99 Cruising & Liveaboard Forum 19 05-26-2007 05:23 PM
