Portable solar - Page 2 - SailNet Community
post #11 of 14 Old 02-11-2012
travlin-easy's Avatar
Originally Posted by Shark0311 View Post
FYI most devices that charge via USB cable charge at 5 watts (5V @ 1A). The exception is the Ipad that charges at 10 watts (5v @ 2A).
Converting DC to AC to DC is very inefficient and unnecessary in most cases. Just use a cigarette lighter adapter. There is no need to use an inverter for the devices that you have listed.
Yep! That's true. All the above listed devices usually come with small, DC adapters for charging and operating the device. I just didn't think about that until you mentioned it. (Guess my mind's starting to go--my wife said it was the second thing! )
travlin-easy is offline
post #12 of 14 Old 02-12-2012 Thread Starter
n0w0rries's Avatar
Thanks all for the feedback. I've seen a few interesting looking devices on Amazon that have a solar charger and battery built in.
Example:
http://www.amazon.com/generation-int...105515&sr=8-11
Anyhow, sounds like they're not quite up to the task yet.
Caribbean 50 Ketch
n0w0rries is offline
post #13 of 14 Old 02-12-2012
Those packages are nice integrations, but, for instance, that one contains a lithium battery equal to two $25 "usb recharger" batteries, plus a tiny solar panel. Well...another $50 would buy you a lot more panel than that. Which of course wouldn't fit in your pocket.
But if you are going off-grid, don't plan to use a lot of power, but want a long-term way of topping it up IF you do...they probably would work well. Personally I just picked up a couple of the usb batteries on sale, I figure they'll give me a boost long enough to get me back to the grid, if I need one. There's also a little hand-crank gizmo for the same purpose, not expensive.
hellosailor is offline
post #14 of 14 Old 02-12-2012
formerly DWJensen
Pau Hana Daz's Avatar
I bought a Suntactics solar charger back in 2010 and have never regretted it. It's a charger only - no battery. It's only 1 amp (5vdc) via USB and it charges my small electronics (iPod, Kindle, smart phone) at about the same speed as using their respective AC cords, and, since it has a USB plug, it works for all three. I've never gotten mine wet, but it advertised as being waterproof.
Amazon link: http://www.amazon.com/sCharger-5-Pow...ef=pd_cp_cps_2
My review on Amazon: Amazon.com: Daz's review of The sCharger-5 is a Powerful Compact Solar...
Daz
Pau Hana Daz is offline
Anybody Use A Portable Ice Maker? montenido Provisioning 17 12-20-2016 01:04 PM
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
Portable BBQ Gulfislander Gear & Maintenance 11 02-21-2010 07:32 AM
Portable A/C S/V Delphinus Gear & Maintenance 4 06-08-2006 02:21 PM
Good Portable GPS bdkorth Gear & Maintenance 17 02-11-2003 02:22 PM
