atomic 4 and man over board - Page 2 - SailNet Community
 4Likes
post #11 of 26 Old 02-11-2012
Superior Sailor
Squidd's Avatar
Coming from a powerboat/watersking background, I thought motoring back to MOB would be the quick and easy way to do it....
Until I thought what if "I" fall in..and wife/buddy/whoevercame for a ride, has to start the motor, the turn the boat and pick "me" up...Now I'm not so thrilled with the idea...
This LifeSling video convinced me that most anyone can turn the sailboat around quickly and safely and pick up MOB "without" the motor running be it inboard/outboard/gas or diesel...
Lifesling - Crew Overboard Rescue - Seattle Sailing Foundation.avi - YouTube
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #12 of 26 Old 02-11-2012
We have always made it a habit to use any hats blown overboard as an impromptu MOB drill.. under sail (which is when hats generally blow off anyway!)
Thanks to that, when a couple of seasons back our 'new' handheld VHF (M34 floater) slipped over the side: One quick jibe, around again, hove to and plucked it out of the water.. Sailing again on the original track in not much more than a minute. Of course that's a lot easier to pick up than a person, but we were in the rescue position right away. Practice pays.
Faster is online now
post #13 of 26 Old 02-12-2012
L124C's Avatar
Huh?
Originally Posted by 123456Wannasail654321 View Post
I an guessing that he is wondering if you'd forgo the customary five minute blowing out of the bilges prior to starting a gas engine.
Thanks for clearing that up for me Wannasail (seriously!) I say....throw the A4 overboard and get a diesel!
L124C is offline
post #14 of 26 Old 02-12-2012
Senior Moment Member
SloopJonB's Avatar
This is a bit of a hijack but pertinent as well. If I ever buy a boat with an A-bomb, one of the first things I will do will be to replace the fuel lines with braided stainless hose and AN fittings. With those for fuel lines and the tank separated like a propane tank I doubt you would EVER smell gas inside the boat.
SloopJonB is offline
post #15 of 26 Old 02-12-2012
Oh come on, guys, get serious. There are hundreds of thousands of power boats with gas engines and it's not like they are blowing up left and right.
Yes, there are accidents with gas (though probably a lot less than with propane) but there is usually some _really_ stupid behavior involved. Like having a smoke while pumping gas (I have seen this).
If you keep your system reasonably in order (use USCG accepted fuel lines, yes rubber is fine!) there is absolutely nothing to worry about. I sure don't loose sleep over my trusted A-4, nee 1976.
MastUndSchotbruch is offline
post #16 of 26 Old 02-12-2012
svHornblower's Avatar
The A-4 in my boat is original and has never been rebuilt. I always start the blower and do the "sniff test" before I start it. Having said that I would not hesitate to start the engine right after I tossed a flotation device to the MOB and then tacked. My goal would be to do the recovery under sail. However, having the engine running and ready if you need it is a prudent step. If you maintain your systems properly you can then be confident in their performance.
1985 C&C 37
Neptune Beach FL
svHornblower is offline
post #17 of 26 Old 02-12-2012
I'd be very wary of starting the engine for a MOB as this is a stressful time and you might make a mistake. The kind of mistake I'm talking about is what happened to a guy in my marina :
The crew fell overboard, so the skipper started the engine. The prop sucked in one of the jib sheets that was in the water. This wrapped around the prop with sufficient force to break the transmission and yank the prop shaft OUT, jamming the prop into the rudder. The rudder would then not move at all. The jib was ripped down and the roller furler wrecked.
The boat was then crippled and unable to sail OR motor, and leaking. The CG had to come and get the crew back who only just made it. The repair bill was $12K.
So if you're sailing when the crew goes overboard, best to complete the rescue under sail. If you're motoring, keep doing that. You have enough on your plate spotting the MOB and getting to him that you won't be able to drop or raise sail in an organised manner.
Faster, chrisncate and SloopJonB like this.
MarkSF is offline
post #18 of 26 Old 02-12-2012
SloopJonB's Avatar
Back in the 70's when there were 4 barge gas docks in Coal Harbour, I was working on West Pender one night when one of them blew up. There was a big concrete highrise between the building where I was and the barge, which was 1/4 mile out in the harbour beyond THAT. Despite all that, it nearly blew out the windows in our building. It was, by FAR, the biggest explosion I have ever experienced.
It was caused by a powerboater (Naturally! ) not blowing his bilges after fuelling. The boat, barge & all burned to the water and people were killed.
Ever since I have been VERY respectful of gas on boats.
post #19 of 26 Old 02-12-2012
JedNeck's Avatar
I guess I am playing with fire but I have never run the blower in any power boat I have owned,for the obligitory 5 minutes prestart, ever.
It never seems like a good idea to tie up the boat launch for an extra minutes to blow out the engine compartment for something that I have never heard of actually happening.
I keep my systems well maintained though...
JedNeck is offline
post #20 of 26 Old 02-12-2012
I would be the last to argue with that!
How much for an Atomic 4? jarcher Atomic 4 20 07-14-2010 04:31 PM
cal 34 atomic 4 tygertyger Atomic 4 1 07-09-2006 10:44 AM
ode to the atomic 4 jwellsfamily4 Gear & Maintenance 1 08-04-2003 12:13 PM
atomic 4 jwellsfamily4 Gear & Maintenance 27 08-03-2003 08:28 PM
Atomic 4 bootsy1962 General Discussion (sailing related) 2 09-11-2001 02:12 PM
