Like Tree4Likes
  #21 (permalink)
Old 02-12-2012
Sailormon6 will become famous soon enough
Originally Posted by JedNeck View Post
It never seems like a good idea to tie up the boat launch for an extra minutes to blow out the engine compartment for something that I have never heard of actually happening.
I saw it happen, years ago, to a 19' inboard runabout. I just happened to be looking right at it, when the boat disappeared in an instant, leaving behind only a shower of splinters falling from the sky, and the two occupants badly injured and in the water.
Nevertheless, IMO, in a true emergency, you should do what you must to respond to the demands of the occasion, and you should balance all the risks in your mind. How great is the risk that the boat will explode if you start the gas engine without running the blower, as compared with the risk that the MOB will be lost or suffer hypothermia or other danger if you don't use the engine to recover them quickly? If you can maneuver the boat under sail sufficiently to recover the MOB, then that's what you should do. If you must use the engine, are the circumstances such that you can do a quick sniff test and run the blower for a minute? If not, then your only acceptable alternative might be to start the motor and cross your fingers. There is a known risk in starting a gas engine without checking for fumes and using the blower, but, that doesn't mean that it is likely that a disaster will follow. If the alternative is that you won't be able to recover the MOB, then that might be a risk that is reasonable for you to take. IMO, you do what you must do under the circumstances.
There might be an alternative to tying up the launch ramp while you run the blower. For example, you might be able to turn on the blower and let it run while you are unstrapping the boat from the trailer and launching it, or perhaps after you launch it, while someone is parking the trailer. You can often find a convenient time to run the blower, if you give it some thought. I'm sure a lot of folks run the blower before they start the engine. Watch how they do it and learn from them.
  #22 (permalink)
Old 02-12-2012
tommays's Avatar
I am real BIG on blowers BUT all these horrible events do get investigated (at least around here) and every time SOMEBODY HAS DONE A Wile E. Coyote AND used and auto electric part or a complete lack of owner care
I am always confused as to how fueling a boat with a sealed tank and the filler and vent OUTSIDE builds up any fumes unless something is broken ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #23 (permalink)
Old 02-12-2012
Squidd's Avatar
Tacky yet Unrefined
Squidd is on a distinguished road
Unless it's fuel injected...carburetor is vented and has overflow capabilities...
"Might as well cast off...If anything bad is gonna happen...It's gonna happen out there..."
"Captin Ron"
  #24 (permalink)
Old 02-12-2012
TQA's Avatar
TQA TQA is online now
Bombay Explorer 44
TQA is on a distinguished road
Step one PRESS THE MOB BUTTON ON THE GPS.
You can only recover the MOB if you can find them.
  #25 (permalink)
Old 02-12-2012
travlineasy's Avatar
Morgan 33 O.I. Perryville
travlineasy is on a distinguished road
Only if the fuel pump valves are stuck open, the float valve of the carb is stuck open and the gas tank is higher than the engine.
Of all the millions of power and sailboats that are powered with gasoline engines, the percentage that meet their untimely demise in this manner is a tiny fraction at best. I suspect more people are struck and killed by lightning in the U.S. than there are gasoline powered boats exploding. Hmmm! I just looked that up, and the number of folks in the U.S. killed by lightning strikes each year is an average of 39. I couldn't find the number of boat explosions, but I'm sure someone here can provide this information.
Gary
  #26 (permalink)
Old 02-13-2012
MarkSF is on a distinguished road
It's been two years since my last MOB practice under sail. (I sound like an alcoholic!) Well, apparently that's how long it takes to be rubbish at it. It took 3 goes to get the lifebuoy back. From now on, we're practicing it once every trip!
Practice those MOB procedures, folks.
Bristol 31.1
How much for an Atomic 4? jarcher Atomic 4 20 07-14-2010 03:31 PM
cal 34 atomic 4 tygertyger Atomic 4 1 07-09-2006 09:44 AM
ode to the atomic 4 jwellsfamily4 Gear & Maintenance 1 08-04-2003 11:13 AM
atomic 4 jwellsfamily4 Gear & Maintenance 27 08-03-2003 07:28 PM
Atomic 4 bootsy1962 General Discussion (sailing related) 2 09-11-2001 01:12 PM
