M17 Bow Chock Placement? - SailNet Community
post #1 of 7 Old 02-17-2012 Thread Starter
Montgomery 17
Perithead's Avatar
Question M17 Bow Chock Placement?
I purchased a pair of bow chocks for my Montgomery 17 and yesterday I found a video that showed the bow chocks in a different place than what I had in mind. I thought I would ask which arrangement everyone thinks is best.
What I envisioned them being used as is a place for my anchor line/lines to run through so that they don't chafe on the forestay as the boat swings at anchor.
This first photo shows where I originally thought they should be.
Here is the placement that I saw on another M17 yesterday.
There is a large cleat to attach the anchor rode to just out if the frame. It is on the centerline of the boat just "below" the photo, another few inches aft.
WHat do you think?
Small is beautiful, simple, cheap, and easy......
Sailing Videos, Woodworking Videos and More!
Perithead is offline
post #2 of 7 Old 02-17-2012
celenoglu's Avatar
Although bow chocks are intended to overcome chafe, they can cause chafe if they arefaraway from the attachment point. It will be a good idea to place them as in the first photo (even closer to the sides) and the cleat or cleats must be positioned more close to them.
celenoglu is offline
post #3 of 7 Old 02-17-2012
overbored's Avatar
the chocks need to be as close the edge as possible or the line will wear through the fiberglass or the wood , the line should touch nothing but the metal chock as it bends and runs down into the water. the cleat placement should be close to the chock so that the stretching of the line does not cause a sawing action on the chock. your cleat location should be ok in the center of your fore deck.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 7 Old 02-17-2012 Thread Starter
Montgomery 17
Perithead's Avatar
Thanks for the replies!
Ok, so the placement in the first photo is what I will go with.
I think they are as close to the edge as I can get them without cutting something like the wood or the metal bracket on the tip of the bow. I would really rather not have to cut either one, but the wood would be my first choice if I really need too.
To cut or not to cut?
post #5 of 7 Old 02-17-2012
celenoglu's Avatar
You better add a metal plate where the rope is touching the boat after the chocks. Otherwise there will be chafe from and to the bow area.
post #6 of 7 Old 02-17-2012 Thread Starter
Montgomery 17
Perithead's Avatar
Wouldn't the rope then chafe on the metal plate?
post #7 of 7 Old 02-17-2012 Thread Starter
Montgomery 17
Perithead's Avatar
After taking into the consideration all of the above comments I have another solution.
Why don't I just cut the wood toerail so that the chock can be right at the edge of the deck?
Here are some photos showing what I'm talking about.
This one is an overhead shot where you can see I have the chock resting on top of the toerail. I am holding it right over the foremost bolt in the toerail. Mounting it here I could use the existing hole that the toerail bolt is going through. Also, with the bolts this close to the edge of the deck my bolts go through the hull to deck joint so there is no bolt going through the sandwiched balsa core.
Here is another angle of the chock in the same place.
Here is a picture that just shows my entire bow area. My only worry now would be the rode chafing again the bolts at the base of the bow rail. Some simple anti chafing material on the lines could solve this though.
Does sound like a better idea?
Lifesling placement caroljeanly C25 and 250 3 02-06-2012 02:56 PM
Broken bow Chock Bolt Brucerobs2 Gear & Maintenance 2 05-10-2010 11:37 AM
looking for mid-rail chock for Bristol 45.5 JohnYates Gear & Maintenance 5 04-23-2010 02:50 PM
Traveler placement bestfriend Sailboat Design and Construction 31 02-07-2008 08:10 PM
Electronics placement stewpee Gear & Maintenance 1 04-20-2001 04:00 AM
