-   -   Rigging question (http://www.sailnet.com/forums/general-discussion-sailing-related/84160-rigging-question.html)
Sublime 02-21-2012 10:20 AM
Rigging question
1 Attachment(s)
I was dropping the mast and the forestay where the cable goes into the tbar got bent.
I wondered if it's possible to pull the tbar off, trim off that damaged section of the cable, and reattach the tbar?
I attached a pic of the piece for reference.
Faster 02-21-2012 10:24 AM
Those connections are generally swaged on and are not removable.. and if you cut it off, cleaned up the cable and reattached a (new) fitting, you'd be several inches shorter and probably won't have the room in the turnbuckle to make up the difference... If the cable kink is serious it looks like you're getting a new stay.
Sublime 02-21-2012 10:40 AM
None of the wires broke, but when it kinked, they separated. Once straightened, it looks normal but I'd imagine it's not as strong as it once was.
I don't know much about what abuse they can take but afaik, they don't like to be bent.
I'd be worried about it if I didn't repair/replace it.
Faster 02-21-2012 11:25 AM
Better safe than sorry... send Knothead a PM!
knothead 02-21-2012 07:14 PM
If the wire is new enough, you might want to consider using a mechanical fitting.
I believe that these are long enough to make up for the wire lost in the swage fitting. If not, you can add an eye-jaw toggle under the turnbuckle to make up the difference.
http://www.secosouth.com/mm5/graphic...wageless_t.jpg
This is a Norseman.
Norseman Swageless Fittings - Seco South, Inc.
