welding my mast - SailNet Community
 2Likes
post #1 of 16 Old 02-22-2012 Thread Starter
NAHANT SAILOR
welding my mast
hello,
last season my spreader pulled off my mast in a storm and put a large hole in the mast. look at attached pictures.
I was wondering if anyone knew if this was fixable by welding a patch and droping the spreader below the hole. Or if i would have to buy a whole new mast tube. The mast is from a PY 23
Any thoughts please let me know,
Thanks,
Matt
NAHANT, MA
mcanty is offline
post #2 of 16 Old 02-22-2012
midlife crisis member
AllThumbs's Avatar
a little bigger pictures would be nice. Looks like there is a lot of corrosion. I think I even see a crack that extends from the hole.
I sail.
AllThumbs is offline
post #3 of 16 Old 02-22-2012
Siamese's Avatar
Ouch. I'd be surprised if welding is a good cure. I'd be looking at riveting a patch on it. Maybe a patch that wraps right around the mast, leaving the sail track clear. Patch about 8" to 12" tall? Do a paint job on the whole mast and come out looking pretty good.
Siamese is offline
post #4 of 16 Old 02-22-2012 Thread Starter
NAHANT SAILOR
yea i thought about doing a rivet patch. do you think it is a big deal to drop the spreader below the patch. will it screw with the strength of my mast
mcanty is offline
post #5 of 16 Old 02-22-2012
I agree. The corrosion looks extensive enough that it makes me think that it may have been the reason that the section failed.
Mcanty, did this happen while you were sailing in a storm or were you moored? Did something catch on a shroud and pull it to cause this to happen?
I would recommend that you have a rigger or a surveyor that you trust take a look at the spar and give you their thoughts before you go through a lot of work and/or expense to repair it.
knothead is offline
post #6 of 16 Old 02-22-2012
olddog60's Avatar
I agree with Knothead. Consult a rigger. I found a hairline crack when I had my boat surved. I consulted three professional riggers and none recommend welding. They all recommended a sleeve.
olddog60 is offline
post #7 of 16 Old 02-22-2012
Cut the whole section out, nice and clean and perfectly perpendicular to the length, and then re-weld with reinforcements straddling the cut..
Flybyknight is offline
post #8 of 16 Old 02-22-2012
I'm just suggesting that, based on what I see in the photograph, having the whole spar thoroughly inspected before repairs are undertaken might be a good idea.
knothead is offline
post #9 of 16 Old 02-22-2012
overbored's Avatar
On a 23' boat it will be a toss up as to the price of a new/used blank or the repair. you need to check the rest of the mast to see if it worth repairing. I have repaired masts with this problem before and everyone is a little different. this one looks like is do to corrosion cracking that started at the fastener holes. you first need to assess how much corrosion and how far you need to be away from the cracks to find metal that is full thickness. I would weld on a cover patch that is at least 7 times as long as the mast is wide above and below the spreader location. and the end of each piece needs to be tapered at least 60 degrees. the cover patch would be welded all the way around and then the spreaders would be remounted. this is the same way we repair a broken mast that has been snapped off or folded over at the spreaders. a properly supported mast has most of the load in compression and this type of repair is much stronger then the rest of the spar
"GOLD RUSH" PRINDLE 16
overbored is online now
post #10 of 16 Old 02-23-2012
Senior Moment Member
SloopJonB's Avatar
Considering where you are, I'd look for a boat junkyard or consignment shop that had a whole rig about the same size. You might even get lucky and find one from the same model of boat.
RobGallagher likes this.
SloopJonB is offline
repairing cracked mast with welding samgary Gear & Maintenance 10 12-12-2011 09:13 PM
HDPE Welding - ???? rikhall General Discussion (sailing related) 10 10-27-2011 09:39 AM
Stainless TIG Welding Equipment? matt2 Gear & Maintenance 5 03-25-2009 08:10 PM
Welding Cable KindOfBlue Gear & Maintenance 10 03-13-2009 06:11 PM
welding stainless exhaust box.... Rockter Gear & Maintenance 7 03-31-2008 05:48 PM
