A better way to run the mainsheet.... - SailNet Community
post #1 of 6 Old 02-22-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
I'm looking at re-running a lot of my running rigging this spring. Currently my mainsheet runs up and down from the traveler car to the boom and then directly aft to a jam cleat on the cabin top. The problem is that the traveller can't be adjusted easily without changing the length of mainsheet, making the traveller nearly useless.
I know that running the sheet forward to the mast, and then back, is the most common way as in this drawing:
I could do this, but I have a 19ft main boom. That would be a lot of running of line and used up deck space. Is there a way to run it from a traveler to a cabintop winch aft of the traveler and still have the traveler be adjustable under load (windward sheeting)?
MedSailor
MedSailor is offline
post #2 of 6 Old 02-22-2012
overbored's Avatar
From the harken catalog page #6. the diagram in the lower right hand corner. 3 to 1. The traveler can be windward sheeted. the deck block can be either fore or aft of the traveler track
Or 2 to1 with deticated winches right hand center of page block on the boom allows the traveler to still work. Harken Hardware Catalog
"GOLD RUSH" PRINDLE 16
overbored is offline
post #3 of 6 Old 02-25-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
I've seen systems like that, but it seems to me that the load would be equally shared by the traveler and the one central block that leads to the winch. Seems like you'd have to have immense backing plates on that one block.
The bigger problem seems to be that when the traveler is all the way out, you'd still have part of the mainsheet running to a centerline block, thus 1/2 of the mainsheet pull would be from the traveler (ie straight down and outboard) and 1/2 the pull would be toward the centerline of the boat.
Do I have this right or wrong? Does the traveler exert more influence because it has more lines going from it to the boom than the one line to the centerline turning block?
MedSailor
post #4 of 6 Old 02-25-2012
A center mounted turning block on the mainsheet will "modify" the effect of the traveller position to a degree but the advantage of having the mainsheet lead always coming from the same place is considerable.. always within reach (if optimally placed) regardless of traveler position, no awkward angles or reach when you're at one extreme or the other on the traveler itself. The cleating angle is also going to be more consistent, making releasing and re cleating easier as well (though I see you're leading to a winch in any event)
Regardless of how you run all that, setting up an easily adjustable traveller is simply a matter of hardware and purchase. Will your traveler be behind the helm? A picture of your cockpit setup would help. Low friction blocks, as small a line as you can handle, and careful arrangement of the leading of the traveler control lines is almost always able to improve access and adjust-ability.
It is possible that your existing traveler track is a major obstacle here.. esp if it's an older style bearing-less T track...
Faster is offline
post #5 of 6 Old 02-25-2012
Second thoughts:
Took a look at the graphic on one of your other threads.. I see the traveler is on the coachhouse roof.. and the companionway is offset.
This may work but it has the disadvantage of every traveler position change absolutely requiring a corresponding mainsheet adjustment... but you're not racing, right?
Mainsheet in red, running through a centerline spring block, through a padeye or clutch to the winch, traveler lines in blue.. the traveler lines could also be rerouted to nearer the winch, I suppose for easier access assuming you have clear space for running these lines across the coachroof.
FWIW (which may be very little....)
Faster is offline
post #6 of 6 Old 02-25-2012
Bristol 45.5 - AiniA
Not sure if this would work for you, but it has worked nicely on my boat which has a very big main (~450 sq ft). When I got the boat. the sheet terminated on the traveller and was adjusted by a winch on the cabin top which wasn't much good if you were at the wheel and no one esle was in the cockpit. What I did at the traveller end (just behind the cockpit) is to mount a really big triple Harken block with a ratchet on the middle sheave (don't remember the number) and a cam cleat to the traveller with 5:1 purchase on it. The plan was to use this end of the sheet most of the time and the winch at the other end when needed. It has turned out that we have not to had to use the winch at all. As the wind pipes up we reef and the load at the aft end remains just manageable. Our traveller is old and needs replacement (an old Nicro I think) but I can still pull the car upwind when needed (not easily but would be much easier with a modern traveller set-up.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
mainsheet traveler sailstein General Discussion (sailing related) 0 04-08-2010 03:16 PM
Mainsheet Blocks krozet Gear & Maintenance 3 03-16-2010 10:44 PM
Mainsheet System tdw General Discussion (sailing related) 31 11-09-2008 05:36 AM
mainsheet Packrat Gear & Maintenance 5 08-08-2008 08:00 AM
Mainsheet car Buck General Discussion (sailing related) 1 02-21-2006 01:44 AM
