Safety Gear - SailNet Community
 1Likes
post #1 of 16 Old 02-23-2012 Thread Starter
Safety Gear
So this will be our first full season on the great lakes (Erie) on our new to us Catalina 30. We will be doing mostly daysailing with an occasional overnight trip thrown in. I am just wondering what you all think is recommended safety gear on top of the required coast guard stuff.
So far we have Inflatable PFD's with harnesses, thru hull plugs, and a radar reflector. I have been thinking of getting a spare handheld VHF and GPS. What other stuff should we have for the type of sailing we are doing? I don't want overkill but I have seen what this lake can become in no time.
Thanks
Joe
jetdrvr393 is offline
post #2 of 16 Old 02-23-2012
jackdale's Avatar
If you have pfd's with harnesses you should get the tethers and jackilnes as well. Mount U bolts with backing plates in the cockpit corners.
First aid kit
MOB pole
Maybe a life sling
Rigging knife for everyone
Waterproof flashlight
Hand bearing compass
Faster likes this.
jackdale is offline
post #3 of 16 Old 02-23-2012
johnnyquest37's Avatar
ASA recommendations
The American Sailing Assn. has a good list of recommended safety items in addition to USCG required items.
ASA Recommended Safety Equipment
Two anchors with at least 200 of rode
VHF radio
Safety harnesses, jacklines, tethers
Compass
First aid kit
Manual bilge pump
Flashlights
Tool kit and spare parts
Soft wood plugs
Other ASA recommended items
Heaving line
Mirror
Searchlight/spotlight
Sunburn lotion
Sunglasses
binoculars
johnnyquest37 is offline
post #4 of 16 Old 02-23-2012
The most female moderator
Donna_F's Avatar
Dock
Congratulations! Don't forget to join the Catalina 30 owners association as well as the Yahoo email list.
You'll want to keep a sharp eye on the water temperature and make sure that you dress for the water temp as much as or even more so than for the air temp.
Also, be sure to leave a float plan with someone back home. I usually email mine to two people.
We learned early on to make sure we had the proper tools to fix anything that might happen with our (then) original engine. Tow insurance is a great investment.
We also carry a spotlight. It's good for illuminating your sail for visibility and also to shine in front of you to see debris before you hit it.
There's plenty of other safety gear you could carry. I don't know what your threshold for "overkill" is. I tend to think that anything that keeps me safe or highly visible isn't overkill.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #5 of 16 Old 02-23-2012
Broad Reachin'
kwaltersmi's Avatar
You might consider putting together a "ditch bag" with duplicates of some of the items suggested here. While this may be overkill for coastal cruising and daysailing in the Great Lakes, it's offers simple peace of mind. We've carried a ditch bag from day one.
Catalina 34
kwaltersmi is offline
post #6 of 16 Old 02-23-2012 Thread Starter
I guess I forgot a few things we already have.
Lifesling
Rigging knives
Flashlights
2 Anchors
First Aid Kit
Signal Mirror
Dye Marker
Several types of flares
My Stantion bases have the U's on them so I was going to use those for my jacklines and I do plan to get tethers.
My threshold for overkill is pretty high, I would much rather buy it and never need it than need it one day and wish I would have bought it.
I really wasn't thinking about a ditch bag though, we don't have a raft so if we ditch, were swimming.....
post #7 of 16 Old 02-23-2012
......I really wasn't thinking about a ditch bag though, we don't have a raft so if we ditch, were swimming.....
Not strictly speaking safety equipment, but if you're coastal cruising the experience is greatly opened up by anchoring and avoiding marinas.. in which case you should have some sort of tender/dinghy.
Worst case you abandon ship to that, so the 'ditch bag' may be a thought anyhow.. and even swimming you might be able to call for help if there's a handheld VHF in there... It should also hold your ID, Passports, etc so you don't lose those, esp if you're crossing borders.
Faster is offline
post #8 of 16 Old 02-23-2012
Jacklines
I'd not use stanchons for the jacklines. On my boat, the cleats are postioned well for jackline use. If your cleats won't work, then install U-bolts (i.e. padeyes) as jackdale suggested.
Some other safety items I carry: handheld VHF stored in the microwave (in case of lightning strike), Lifesling, heaving line, and assorted hacksaws to cut away standing rig in the event of a rig failure. All of our PFDs have a whistle attached and are marked with reflective tape front and back. At night, each crew carries a chemlite (light stick).
On my wish list is a MOB pole/life buoy combination that will also trigger the MOB function on the chartplotter.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
post #9 of 16 Old 02-23-2012
Barquito
Barquito's Avatar
This might be obvious, but, the correct attitude toward safety may be just as important as all the stuff. For example, clipping in while alone on deck, teaching all onboard how to start the motor, practicing MOB, etc.
Barquito is offline
post #10 of 16 Old 02-23-2012
pdqaltair's Avatar
Many (most?) stantion bases are neither trough-bolted (many are screwed on) nor have backing plates capable of holding 5,000 pounds (yes, the forces are that high, because of the tight-rope effect).
Bow cleats are generally fine, but the stern cleats are too far back (you can go off the back). Thus, Jackdales recomendation for in-cockpit u-bolts. Remember that the clip on the u-bolt end MUST be a locking biner; they come off easy.
(some calculations about fall energy)
Sail Delmarva: Sample Calculations for Jackline Stress and Energy Absorption
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
Safety gear questions jrd22 Gear & Maintenance 6 09-19-2008 09:06 PM
Maintaining Safety Gear Tom Wood Seamanship Articles 0 12-21-2001 07:00 PM
Maintaining Safety Gear Tom Wood Gear and Maintenance Articles 0 12-21-2001 07:00 PM
Maintaining Safety Gear Tom Wood Cruising Articles 0 12-21-2001 07:00 PM
Maintaining Safety Gear Tom Wood Her Sailnet Articles 0 12-21-2001 07:00 PM
