I just want to know how fast I'm going. - SailNet Community
 3Likes
post #1 of 23 Old 02-28-2012 Thread Starter
rhr1956's Avatar
I don't want to install a traditional knotmeter. Since I'm weekend sailing on a lake, I certainly don't need a chart plotter. Is there a simple GPS based gizmo that will tell me how fast I'm going?
rhr1956 is offline
post #2 of 23 Old 02-28-2012
Any handheld GPS will give you Speed Over Ground. On a lake that would be acceptable unless there are areas of strong current.. when trimming sails it's nice to have Speed thru the water as opposed to SOG.
Handheld GPSs are becoming rather inexpensive.. non marine models may not give you the option of knots (nautical miles per hour)
Faster is offline
post #3 of 23 Old 02-28-2012
Rangernewell's Avatar
Send a message via Yahoo to Rangernewell
I just use the GPS out of the truck. Gives me a good indication where I am and roughly how fast I'm going. Although it only reads the speed in mph or kph, it does give me an idea on what to do with the sails.
Rangernewell is offline
post #4 of 23 Old 02-28-2012
g0twind's Avatar
If you have a smartphone you can download any number of apps for speed over ground.
From the Android market I use SailDroid or GPS Test
1974 Paceship PY23 "Barely Awake"
Hull # 001
g0twind is offline
post #5 of 23 Old 02-28-2012
denverd0n's Avatar
I consider a knot meter to be a fairly important piece of equipment, and critical if you want to learn to sail better. Why? Because it is the only instrument you have that can instantaneously tell you if your boat is speeding up or slowing down.
Doesn't matter if it is accurate. If you trim the main in a little, how do you know if that helped or hurt? The only way is by looking at the knot meter and seeing if your speed increased or decreased. Again, it doesn't matter if the speed it is reporting is accurate, it only matters that you can see how it changed. Then you will KNOW what your adjustments to sail trim are doing.
Of course, if you don't care to know how changes in sail trim affect your speed through the water, then you don't need a knot meter. As a SAILOR, though, this is something that I consider very important.
Faster likes this.
denverd0n is offline
post #6 of 23 Old 02-28-2012
Lake Superior Sailor's Avatar
Cheap way out ! Check out Ebay # 120867991235.. Tafrail log Simple Knotstick..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #7 of 23 Old 02-28-2012
Remember you're a womble
PaulinVictoria's Avatar
Garmin 72H. Waterproof, floats and you can even do basic waypoint navigation with it. Job done.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #8 of 23 Old 02-28-2012
These have ranges greater than required but may serve your purpose,
You could get more info for the buck with a handheld GPS, but if you don't need it this might be all you want.
"Just call me TB"
capttb is offline
post #9 of 23 Old 02-28-2012
jsaronson's Avatar
There is a portable gps called a Speedpuck. Pricey but what you are looking for.
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #10 of 23 Old 02-28-2012
Garmin eTrex
I'm a weekend lake sailor with the same need - how fast are we going? If I had an Apple or Android smartphone, I would download one of the GPS apps to provide me with this info. But, I don't have a smart phone.
A friend on the Yahoo Catalina 22 group recommended the Garmin eTrex. About $100 - yellow, waterproof, speed in knots or mph, waypoints, use it for sailing/hiking/biking. That's what I'll be buying. Check out the Garmin website for the low-end, low-cost, eTrex 10 or 20.
- Bob
bnaylor is offline
Wow! That Was Fast! arknoah Learning to Sail 6 07-17-2011 10:11 AM
need advice fast! Trouty General Discussion (sailing related) 24 06-28-2010 10:50 AM
Want fast?? here's fast for you... Giulietta General Discussion (sailing related) 45 11-17-2007 07:09 AM
How fast is to fast eric97217 General Discussion (sailing related) 5 04-27-2004 01:53 PM
too much too fast? jbarros Boat Review and Purchase Forum 13 06-26-2003 10:03 AM
