6" opening portlight, bronze - SailNet Community
post #1 of 5 Old 03-04-2012 Thread Starter
I am having trouble sourcing a 6" opening portlight, with a deep spigot (50 mm) in bronze.
It needs to be good quality.
I have approached New Found Metals and they have a decent 5" opening portlight with deep spigot, but their 6" model is available only in stainless steel and it will not look right as the rest of the openings are bronze.
The available planar surface is almost exactly 12" square. the 5" portlight has an overall diamater of 8" and the 6" portlight typically about 10".
I cannot find the 6" model in bronze, however.
Rockter.
Rockter is offline
post #2 of 5 Old 03-04-2012
billsull's Avatar
There is a 6" opening portlight in the Davey & Co. catalog (a literary masterwork, IMHO), but the spigot depth is 44mm vs. 50mm.
R&W is a distributor here in the US (and a great store in its own right).
Ropes | Climbing Rope | Surplus Rope | Paracord | R&W Rope
Bill Sullivan
Allied Seawind 30
Bristol 24
Old Saybrook, CT
billsull is offline
post #3 of 5 Old 03-04-2012 Thread Starter
BillSull :
Thanks.
The thickness I need is about 45 mm, so i was trying for 50 mm.
I have sourced a 5" opening portlight, but it would be good to find a 6", I think.
Maybe I should just settle for the 5" ??
Rockter is offline
post #4 of 5 Old 03-04-2012
billsull's Avatar
I guess that depends on the whether it would be tougher to deal with fitting a 5" portlight into a 6" hole (which is always more difficult than the other way around). Personally, I lean towards the latter, especially since the spigot depth on the 6" one is only off by a millimeter. A millimeter or two never stopped me from installing anything - I have two sledgehammers on the boat right now!
Bill Sullivan
Allied Seawind 30
Bristol 24
Old Saybrook, CT
billsull is offline
post #5 of 5 Old 03-04-2012 Thread Starter
Re: 6" opening portlight, bronze
BillSull :
The problem is that the spigot will not be deep enough and water will get into the bulkhead.
Rockter is offline
Bronze Portlight "Wing nut" BirdBrain333 Pacific Seacraft 6 03-18-2010 08:07 PM
"bypassed" bronze seacock Alden44GER Gear & Maintenance 2 02-04-2009 09:41 AM
source for a 1 1/2" bronze elbow with hose barbs lassrl Gear & Maintenance 6 01-13-2009 12:07 AM
Opening portlight gasket material?????????? Dmarina Gear & Maintenance 5 10-14-2008 03:59 PM
Bronze portlight install GBurton Gear & Maintenance 8 11-22-2007 01:11 PM
