Adding reflector to augment Solar - SailNet Community
post #1 of 3 Old 03-04-2012 Thread Starter
I am considering adding two reflector panels (that will only be deployed in low wind days) alongside my solar panels mounted on the Bimini. They will have limited movement for some hourly adjustment. Does it appear to have any value?
Think the neck tanners from the 1950's
Charles
micheck is offline
post #2 of 3 Old 03-04-2012
Bristol 45.5 - AiniA
No reason why it would not work. I would suggest you try it without first to see whether you need the boost. Makes more sense to do everything you can to avoid shading. Even the shadow of the backstay can have a serious effect.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #3 of 3 Old 03-04-2012
Re: Adding reflector to augment Solar
Just something to be aware of here is that the increased heat caused by reflectors could have a bad impact on your panels on very bright days.
I'd ask Mr. Google about it
wheelies is offline
Radar reflector brokesailor Gear & Maintenance 9 08-14-2011 07:52 AM
Adding second Solar Controller funjohnson Electrical Systems 7 02-01-2011 01:45 PM
Another radar reflector? T37Chef General Discussion (sailing related) 13 03-15-2010 08:01 PM
Do I need a radar reflector? Patbarbeau Gear & Maintenance 61 07-24-2009 04:49 PM
best radar reflector for cruisers hathanger General Discussion (sailing related) 8 09-30-2006 10:39 PM
