Travel Lift Approach - SailNet Community
 22Likes
post #1 of 28 Old 03-04-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
Hello Gurus,
I have scheduled my first haulout for later this month at Port Annapolis Marina and I really like to avoid looking like a total idiot! To be honest, I'm not really sure how to approach the travel lift bay. Does it make a difference if I approach bow first or stern first? What is the typical haulout procedure? I'm planning to stop by a day before and check things out but I figured I should ask the experts first.
Thanks in advance!
flyingjib is offline
post #2 of 28 Old 03-04-2012
flyingwelshman's Avatar
Re: Travel Lift Approach
I approach bow in and tie off at a dock just outside the travel lift bay. The lift operator usually directs me to a spot as there are usually boats ahead of and behind me.
Once at the dock I tie off and lock my tiller to centre. The boat is manhandled into the slings.
The guys at the lift are always helpful and will give directions.
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #3 of 28 Old 03-04-2012
chef2sail's Avatar
Bow first..Its just like docking in your slip. Usually you tie up your boat in the Travel lift slip and they guide it in with the straps under it in the appropraite places from there,
Port Annapolis Travel lift slip is not unusual. Dave from Auspicious keeps his boat there, maybe he can comment.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #4 of 28 Old 03-04-2012
HANUMAN
RobGallagher's Avatar
Talk to them first. Some places have a dock for you to tie up at just outside, others may put you into a slip and bring you in later under side tow with their work boat.
If they do want you to come in under power it will most likely be bow first. Most likely someone may still meet you at the work dock just outside the lift to take lines so they can keep you centered till the straps are in the right place.
I'm willing to bet they will put you on the work dock and walk your boat in.
p.s. Damn that yard is pricey!
flyingjib likes this.
RobGallagher is offline
post #5 of 28 Old 03-04-2012
Depends on the travel lift and the arrangement on the hard.. We've been to several that want you to back in. I'd check with them first.
In any event you virtually never 'drive in'.. and around here you can't ride the lift anyhow so you're off the boat at the finger dock, and they pull the boat into place with boathooks.
Be prepared with a profile drawing or marks or reference points on the boat for avoiding impellers, shaft and strut, know where your keel ends etc so there's no nasty surprises half way up. Pull the knotmeter impeller and insert to plug beforehand to be sure, if you can. Also have an idea where major bulkheads are for placing stands once on the hard.
jrd22, jackdale, SloopJonB and 1 others like this.
Faster is offline
post #6 of 28 Old 03-04-2012
travlin-easy's Avatar
This will depend a lot on your boat and the travel lift configuration itself. In my case the travel lift is more than adequate to lift the 13,000-pound boat and has a 25,000-pound (12-ton) capacity. Normally, the boat would be picked up bow first, but my roller furling system is essentially a solid length of aluminum that goes from the top of the mast to the bow sprit. Consequently, the boat is backed in, the back-stay is removed and the boom lowered so it will clear the lift's cross beam. Once ashore, the boat is lowered on the jack-stands, they're chained in place and the back-stay is reattached.
Regardless of where I have the boat hauled, I always provide the marina with a copy of the boat's construction diagram so he knows exactly where to place the travel lift straps. Some boats, such as my friends Morgan 32.2, has arrows etched into the superstructure indicating the travel lift pickup points. He usually places a couple strips of blue masking tape over them so the spots are easily seen and informs the travel lift operator--just to be on the safe side.
One last tip. Most of the marina place the boats on gravel or crusher-run covered lots. During the first couple weeks, especially if the weather is wet and windy, the jack stands tend to sink into the ground a bit. Be sure to check and tighten them regularly during that time to prevent the boat from shifting and placing too much pressure on the hull.
Good Luck,
Gary
SVAuspicious and flyingjib like this.
travlin-easy is offline
post #7 of 28 Old 03-04-2012
Hmmm
Bilgewater's Avatar
You won't look look like an idiot, they get this all the time and every kind of vessel imaginable. Go there and ask them the procedure...that's the way to do it. Or just pull your vessel up to the float and they'll let you know what to do. Every lift is different, every procedure is different, it will work out fine.
The important thing as has been mentioned already is knowing where the straps should sit and have it marked.
Here's an example of a variation in lifts and procedures you could come across.
Lifting - In this case, I secure to the float on the left.
Up the hill - towing the lift with the help of a front end loader.
Back down the hill (under it's own power) You wouldn't find a lift like this anywhere else...it's unique.
jrd22, Faster, chef2sail and 2 others like this.
Impulse III
Truant Pilothouse
Bilgewater is offline
post #8 of 28 Old 03-05-2012
...Only in Lund, eh Steve??
Faster is offline
post #9 of 28 Old 03-05-2012
chef2sail's Avatar
Now thats unique...
Parkville, Maryland
Our blog-
post #10 of 28 Old 03-05-2012
Hmmm
Bilgewater's Avatar
You got it Ron! If you build it...they will come.
Impulse III
Truant Pilothouse
Good approach to NYC? labatt General Discussion (sailing related) 5 05-13-2007 12:51 PM
