Ideas on securing wires inside mast? - Page 2 - SailNet Community
 6Likes
post #11 of 51 Old 03-07-2012
casey1999's Avatar
Re: Ideas on securing wires inside mast?
I've got the same problem. Jon's method above sounds good. I've got a long length of rebar that could be used in place of iron pipe.
One thing I question is how do you satisfy the AYBC requirement of supporting the wire every 18 inches (to satisfy you would need a wire tie support every 18 inches coming down the mast, otherwise all of wires weight is supported from one point at the top). With wire in the mast seems nearly impossible. And how do you adequately support 40 feet or more of wire from the mast head? My wire just swing around and rub inside the mast, surprised they still work and have not broken loose from the top of the mast.
casey1999 is offline
post #12 of 51 Old 03-07-2012
"One thing I question is how do you satisfy the AYBC requirement of supporting the wire every 18 inches "
I suppose that means doing what the utility companies do on powerlines. Run a separate steel cable, secure the other wires to it every 18". Oh did I forget? To mention do that while the mast is down, now insert the whole bundle in your conduit and secure it from the top, let the steel cable take all the weight.
Sometimes there's no easy or practical way to retrofit.
hellosailor is offline
post #13 of 51 Old 03-07-2012
casey1999's Avatar
Know as a messager cable. Good idea. Maybe use a 1/16 inch AmSteel line instead of steel cable.
post #14 of 51 Old 03-07-2012
No, a messenger cable is used strictly to move other wires from "this end" to "that end". It isn't used to secure them in place. A messenger cable needs to be at least twice as long as the wire run, so it can go back and forth, and still not be lost at either end. And available to move, without moving any existing wiring that remains in place.
post #15 of 51 Old 03-07-2012
Swab
vega1860's Avatar
Originally Posted by travlineasy View Post
(snip)
I talked with a couple marinas and they recommended installing a PVC conduit in the mast, which would really be expensive.
(snip)
Has anyone else experienced this problem, and if so, I could sure use a solution.
Thanks in advance,
Gary
Yes I have had this problem. Dad always said "Anything worth doing is worth doing right". He was seldom wrong. Another sage once said to me "If you don't have the time (Or money) do do it right, when will you have the time to do it over?"
vega1860 is offline
post #16 of 51 Old 03-07-2012
casey1999's Avatar
You previous description was for a messenger cable:
Cable Construction Details
The above definition is for a cable puller:
Engineer's Corner -- Installing Communications Cable in Conduit: Pulling Lubricants, Blowing, Tension Calculations, Software, Fiber Optics, Friction Reduction
post #17 of 51 Old 03-07-2012
minnow1193's Avatar
Just a thought for consideration- if you are ok with drilling some holes in the mast, maybe consider injecting some expanding foam insulation at various points to anchor the wires? Could easily be removed down the road if necessary. ??? Looks like my PO had done something similar. If foam is not exposed to UV should hold up just fine.
minnow1193 is offline
post #18 of 51 Old 03-07-2012
Casey, Belden ought to know their stuff but I've always been taught, always heard the usage, of a "messenger line" (cable, etc.) as being the line you string between here and there, and use to pull other cables or wires back and forth. By riggers, electricians, anyone who has run one.
And a "cable puller" from the electricians I know, is the thing (gizmo or single cable itself) you attach to one end of a cable, to pull it through. And then you need to run a new messenger line to run another new cable, because you've just pulled out the one that was there before.
Does a "northerly" wind blow fom the north or the south? Despite all the definitions both ways, a northerly wind blows TOWARD not FROM the north. A North wind blows rom the north. A "northerly" one doesn't. Same same I suspect, just as so many people have taken to saying they will "insure" that something gets done, when they mean "ensure". Go back 20 years and the differences were clear, but today the meaning has been largely lost.
Call me stubborn, adamant (two sides of the same coin) or simply wrong, but I'll stand by the only usage I've ever heard all these years and call Belden wrong on this one. Even if it is right in their internal industry jargon.
post #19 of 51 Old 03-07-2012 Thread Starter
travlin-easy's Avatar
Looks like the minimum at the marina for a conduit installation and rewiring the mast will be somewhere between $800 and $1,000, which is a lot of money, at least to me. The same marina will be more than happy to send a bunch of foam blocks down the mast for about $150 if I buy the foam rubber. Think I'll end up with the foam rubber blocks.
Gary
travlin-easy is online now
post #20 of 51 Old 03-08-2012
casey1999's Avatar
Gary
I was looking at my mast last night. I have enough holes here and there to pull the wire out the side of the mast and attach a thick wire tie that is say 1 foot long. I would leave the tail on and that would restrict the movement of the wire some, and maybe enough to silence. Maybe you could try this.
If you jam in the foam, what if you need to run wire in the future. Can they be removed? What about internal halyards?
Electrical wires inside mast making much noise akin_alan Gear & Maintenance 10 04-13-2011 07:13 PM
securing companionway from inside rmeador Gear & Maintenance 31 10-07-2010 07:46 PM
wires going up the mast - where do they go in? jarcher Gear & Maintenance 4 10-10-2008 04:43 PM
Securing Wires jbondy Gear & Maintenance 4 07-02-2008 03:33 PM
Securing floor panels inside a sailboat fourgeau Announcements and Suggestions Box 0 05-05-2008 07:22 PM
