Sailing using water current - SailNet Community
post #1 of 11 Old 03-07-2012 Thread Starter
For long time it puzzles me that we can sail into the wind if we can apply the same principle to sail against the water current.
I have posted a video showing several configurations it is at:
(You my add a 'non-paddling paddle' to increase the speed if you need to sail against the current)
And Happy sailing
Phi
PhiTran is offline
post #2 of 11 Old 03-07-2012
tommays's Avatar
Re: Sailing using water current
After going faster than the wind when dead down wind was proven with a clever design i would guess anything could be done BUT not necessarily in a practical manner
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 11 Old 03-07-2012 Thread Starter
This is the current practice to move a boat upstream
Stock Footage - Chinese Laborers pull boats upstream from a river which runs between high mountains in China.
Or.
Pulling a Boat Along the Yellow River, China - SU001009 - Rights Managed - Stock Photo - Corbis
The sample I posted simulate the heavy loaded watercraft.
PhiTran is offline
post #4 of 11 Old 03-07-2012
Great stuff. But as a physicist Id need more to be convinced. There is some debris in the water that seems to float against the current as well.
fjonball is offline
post #5 of 11 Old 03-07-2012 Thread Starter
On the physic side, it is the aerodynamic lift force of the fluid effects on the foil (airfoil) as if of the airplane or of the sail going into the wind. A google may give much more info. As of physic, water and air are both fluid, but water are 1000 times the density, the force.
The setup is a water hose on left side of a manger, the debris stub are the result of the turbulence when the water hits the back (right) wall, As you may notice that 'boats' start speeding up when they pass the turbulence area.
Happy sailing.
Phi
PhiTran is offline
post #6 of 11 Old 03-10-2012
Lake Superior Sailor's Avatar
I have seen a car fairy that was self operated on a river,A cable accross the river held the Fairy and a vane in the water moved it accross using the water current! It could handle 4 cars ,But: you could wait a long time till someone came accross. It could be sent accross empty though....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #7 of 11 Old 03-14-2012 Thread Starter
I also post a video showing that changing the attack angle one can move the boat model up/down the stream using its kinetic power itself.
it is:
Thanks
Phi
PhiTran is offline
post #8 of 11 Old 03-14-2012
Interesting stuff; there has been more experimentation on hydrofoils as of late. The boat of the future may very well change the paradigm of sailing bigger than the change from square sails to trianglar sails, with a coresponding change in performance.
Our engineering technology has grown in order of magnitude leaps since computer modeling became common. So far shipbuilders have been stuck in the past as races often disqualify earth shaking breakthroughs, and the public market like in cars follows the racing market. Buyers are slow to buy new unproven designs. Look at the continuing arguments over multihulls.
Would you buy a sailboat with no visible sails?
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #9 of 11 Old 03-14-2012 Thread Starter
This is not a sail boat as it is commonly understood. For example: one can not use this on the ocean (no water current) . . . . Nor it is to replace the engine, it's just an add on for those how are using river as a mean of transportation.
One may consider to build for his/herself a pair paddle like foil (as in first video) for emergency purpose if in case his engine stops function for he/she to somewhere upstream. Other purpose could be for rescue personnel to partially nullify the rage of the current, etc . . . . (as seen on TV)
My ultimate purpose is: if somehow, some way the the people in the underdeveloped area in the world would have the technology exposed. these a free energy to help them travel upstream will indeed be a big help.
(I m in TX too --- near Houston)
Phi
PhiTran is offline
post #10 of 11 Old 03-14-2012
What about sailing with the current? 4 knots favorable current increases your apparent wind by 4 knots, right. So in an otherwise flat calm, you can just bear off and sheet in, huh?
sorry, thread hijack.
nolatom is offline
Sailing rivers??? Current?? runner Learning to Sail 15 01-26-2010 06:52 AM
At sea. Asian Record Circuit: Ellen MacArthur and B&Q sailing through rough water to Hong Kong @ BYM Sailing News NewsReader News Feeds 0 04-21-2006 04:31 AM
At sea. Aviva Challenge: Good sailing but no rest for Dee Caffari as water maker plays up @ BYM Sailing News NewsReader News Feeds 0 04-10-2006 11:15 AM
Against the current? healthyplanet General Discussion (sailing related) 3 03-12-2006 05:31 PM
Against the Current Don Casey Her Sailnet Articles 0 10-27-2002 08:00 PM
