Lead 'boot' - yes/no? - Page 2 - SailNet Community
 1Likes
post #11 of 25 Old 03-07-2012
Lake Superior Sailor's Avatar
Re: Lead 'boot' - yes/no?
Install a wine cellar in the bilges & one way or the other it really won't matter!...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #12 of 25 Old 03-07-2012 Thread Starter
OK - the wisdom has spoken - I will move on to some other silly project - Thanks
Charles
micheck is offline
post #13 of 25 Old 03-07-2012
Closet Powerboater
MedSailor's Avatar
I think you SHOULD put the lead boot on the keel?
Why?
That way when every sailor who ever walks by your boat ask's you "WTF is that?" You can answer, "It is DAS BOOT!"
Other than the above, I see no upside.
MedSailor
MedSailor is offline
post #14 of 25 Old 03-07-2012
Senior Slacker
SlowButSteady's Avatar
Originally Posted by micheck View Post
OK - the wisdom has spoken ...
Well, a bunch of duffers with nothing else to do have spoken. But, I think you made the right decision.
Faster likes this.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #15 of 25 Old 03-08-2012
grumpy old man
If your boat is initially tender adding 50lbs. to the keel will not help much. Your increase in displ and your new waterplane will help some and you will see an increase in stability once you hit about 20 degrees of heel. What is the current draft of the boat? If we knew what kind of boat you had it would help.
Bob's Blog ....
bobperry is offline
post #16 of 25 Old 03-08-2012
Barquito
Barquito's Avatar
500 lbs at the bottom of the keel (vs. 500 lb wine cellar in the bilge) would help a fair amount with ultimate stability, no?
If it is also intended as a reef-feeler appendage, it would be more useful if it extended up the leading edge of the keel a bit. Maybe a bit of 5200 to keep from having to drill through an encapsulated keel? (kidding of course)
Barquito is offline
post #17 of 25 Old 03-08-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by deniseO30 View Post
Ok who doesn't like the boat "tipping"? Hmmmm? It took 2 season for me to get used to it myself.
It took me 2 seasons to learn that having the lee rail 6 inches under wasn't fast. I preferred beating with a large heel angle from the first day I went sailing - it was (and is) better than any arcade ride I was ever on.
SloopJonB is offline
post #18 of 25 Old 03-08-2012
SloopJonB's Avatar
Hey... I am NOT a duffer, I am a curmudgeonly geezer.
post #19 of 25 Old 03-08-2012
Senior Slacker
That's odd. I haven't seen you at any of the meetings.
post #20 of 25 Old 03-08-2012
DelmarRey's Avatar
I've always thought they were called bulbs >>> MarsKeel Technology Keel Draft Reductions
And you can get them custom made to fit your keel.
The next question is; can your mast and rigging take the extra stress (COE/COR). It's a good thing you don't have keel bolts.
"Faithful are the Wounds of a Friend, but the Kisses of the Enemy are Deceitful!"
DelmarRey is offline
mast boot jjns Gear & Maintenance 18 10-04-2009 09:11 AM
Boot Key Harbor lowryjim Cruising & Liveaboard Forum 1 11-19-2007 12:28 AM
Boot-top touch-up saildork Gear & Maintenance 5 10-17-2007 10:29 PM
Leaking Mst Boot Kelly Somers Gear & Maintenance 7 10-01-2007 11:13 PM
Boot Key Harbor PaulOuellette Cruising & Liveaboard Forum 1 12-13-2002 07:37 AM
