Broken sail slides - Page 2 - SailNet Community
post #11 of 18 Old 03-08-2012
One of None
deniseO30's Avatar
Re: Broken sail slides
How about the main halyard? if the luff isn't stretched and the foot isn't stretched well with the out haul, the main will be baggy too. I used to be rather nervous about stretching them. Good thing about plastic slides.. they go before the sail rips most of the time.
Good luck!
My last project!
deniseO30 is offline
post #12 of 18 Old 03-09-2012
Too bad black slides are so rare. Black plastic is far more immune form UV damage than white ones , which let the UV shine right thru them. I welded up my top slide from stainless. Not hard to do, may build more of the stainless ones.
Brent Swain is offline
post #13 of 18 Old 03-09-2012
lajimo's Avatar
Sounds like too much stress on the sail during your gybe. If you had a reef in the main you could have flown your jib with good control and had an easier time coming about.
lajimo is offline
post #14 of 18 Old 03-09-2012
Experience has taught me to replace the sail slides and the batteries when you buy a used boat. Slides are cheap but not always easy to get and, as you discovered, alot of them break at once. Your local WM may have three in your size...
fordo is offline
post #15 of 18 Old 03-09-2012 Thread Starter
itsaboat's Avatar
That is something that I am working to learn. My thought was "heavy winds, reduce sail by keeping the jib down". But you are saying that flying a jib and reefing the main would have been better?
Pearson 27
itsaboat is offline
post #16 of 18 Old 03-09-2012 Thread Starter
itsaboat's Avatar
I didn't see black slides available, but at $1.40 to replace the slides and shackles every few years I am okay with it.
Pearson 27
itsaboat is offline
post #17 of 18 Old 03-09-2012
This is almost always better... results in a more balanced sail plan, esp going upwind, but even beam or broad reaching some headsail will ease the loading on the helm.
Off the wind you can roll in or out as required if you have a reefing furler, upwind I'd prefer a proper sized headsail for the day.
btw we have black slides on our Quantum main (2nd hand from the J 105 fleet)
Faster is online now
post #18 of 18 Old 03-09-2012
chef2sail's Avatar
Yes..better to reef and fly a jib either furled or smaller on. Having the jib up will make it more balance, allow you to head closer to the wind, and also come about more easily as the jib will bring the bow through the wind and you will have less chance of stalling and getting caught in irons as you come about.
Also the balance of power of the wind is more centered over your keel with the jib up and mainsail than one and not the other.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
How did I break my sail slides? sailak General Discussion (sailing related) 6 06-13-2011 01:23 AM
Problem with Sail slides Iannis Gear & Maintenance 16 09-13-2010 05:08 PM
Nylon sail slides / slugs Atkinsericjr808 Gear & Maintenance 17 07-25-2010 10:32 AM
Fredericksen sail slides JohnDrake Gear & Maintenance 0 10-15-2002 07:03 AM
sail slides newuser Gear & Maintenance 0 06-30-2001 09:47 AM
