What sailing knife do you use? - Page 4 - SailNet Community
 16Likes
post #31 of 119 Old 03-13-2012
Over Hill Sailing Club
smurphny's Avatar
Re: What sailing knife do you use?
Originally Posted by Minnewaska View Post
I'm not sure any knife is good for cutting yourself free from a tether. Nothing i see above is going to be opened while you are being drageed behind a boat. For cutting the tether, I have a razar sharp S-cutter on a lanyard inside the PFD. The blade is covered in wax, which would slice through when pulled against the line. Nothing to open and it sits inches from the tether itself.
You must be referring to the Letherman multi-tool, which I agree is not good for emergencies. However, the Leaherman knife is great.
Some sort of s cutter sounds like a good idea for tethers although the kayak knife is designed specifically to cut through synthetic line in river rescue. It'll go through a tether or 3/4" double braid lickety split.
smurphny is offline
post #32 of 119 Old 03-13-2012
Tundra Down
downeast450's Avatar
Originally Posted by celenoglu View Post
I use this one:
Every tool has to be alone. Knives are for cutting. Including other tools to the same handle might be an easy way to carry them but using them is not. You may need a screwdriver and a plier for the removal of a machine screw.
Knives on board are needed for cutting and generally in an emergency. This knife can be carried easily, you can open it with one hand, the blade is long enough to cut a rope in one strike. The blade locks when you open it.
I have collected a few over the years. I was given one of these for Christmas and I haven't used it aboard yet. It is a great knife. Its one handed facility is the best of any knife I have.
Down
downeast450 is offline
post #33 of 119 Old 03-13-2012
RichH's Avatar
Any 'sheath knife' that can be honed to a razor sharp edge and will keep that 'edge' without having to continually sharpen and 'strop'. I have 'tools' for other stuff ... gouges, scrapers, screwdrivers, scissors, corkscrews, saws, and nose hair extractors, etc.
When you NEED a knife, you want a 'sharp' one and one where blade wont 'fold' onto your fingers. :-o
redfishnc and vega1860 like this.
RichH is offline
post #34 of 119 Old 03-13-2012
pdqaltair's Avatar
Assuming the knife is for safety (cutting yourself free of a tether or rigging, fo exanple), there are 3 tests it should pass that many of the sugestions do not:
1. No point. The tip should be relatively blunt so that stabbing yourself is difficult.
2. Can you retrieve it from the holster of pocket with one hand, in the dark, in a panic in the surf. Seriously, most of the belt holsters would result in the knife being on the bottom of the ocean. A lanyard may be best. I favor a deep pocket as a compromise.
3. Can it be retrieved when the PFD is inflated. No kidding, with some inflatables you might be surprised.
On side note, Practical Sailor just reported that some inflatable PFDs/harness combos block access to the release on the harness snapshackle when inflated. Sounds like a shamfull lack of realworld testing. I hope you are doing real MOBs with real people in the water with the equipment you really use (we do). Otherwise, it's no plan at all and the safety talk is lip service.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #35 of 119 Old 03-13-2012
GeorgeB's Avatar
My favorite is a Myerchin with serrated blade, marlin spike and a shackle key built into the blade. Fortunately, most of my shackles have mousing holes in the pin so I can use the marlin spike. I can also use it to trip my Tylaska shackles too. Unfortunately, the serrated blade can get dull cutting Kevlar and Amsteel pretty quickly so I keep a ceramic blade knife down in the Nav Station.
A long, long time ago I used to keep my knife in my pocket but not anymore. The one time I really needed it, it was in my pocket under my bibs which were under a sweater under a jacket that was under a life vest. I could not dig it out in time. I now wear the knife on a detachable lanyard around my neck. Never had an access problem since.
I’m a little bit nervous about something sharp in close proximity to something inflatable. I’d rather have it around my neck than clipped to my vest. My tether has a quick disconnect shackle at the vest end so I don’t need to cut the line.
GeorgeB is offline
post #36 of 119 Old 03-13-2012
jackdale's Avatar
Originally Posted by GeorgeB View Post
My tether has a quick disconnect shackle at the vest end so I donít need to cut the line.
There was a recall of tethers with quick releases that did not operate properly. I can also see how the release could get jammed in a D ring.
njadventure likes this.
jackdale is offline
post #37 of 119 Old 03-14-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
Thanks for all the opinions and experience so far. One major thing I need to reconcile is fixed vs folder. In the fixed category it looks like rafting PFD knives and SCUBA BCD knives are contenders.
If I go for a folder it'll be the Boyd knife or the Wichard. I like the idea that the Boyd knife will never rust and practical sailor really liked it, but I wouldn't want the marlinspike breaking off on a knife that costs that much.....
Check this out, Practical Sailor reviewed sailing knives:
Article here:http://boyeknives.com/images/review.pdf
An independent and very detailed review (thesis!) of knives here:
http://www.franciscoresearch.com/ima...ife_Market.pdf
MedSailor
MedSailor is offline
post #38 of 119 Old 03-14-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
Best selection of sailing knives I've seen yet is here:APS - Knives
MedSailor
post #39 of 119 Old 03-15-2012
Yamsailor
Yamsailor's Avatar
I use the Boye Knife. It is the best sailing knife I have ever owned.
Folding Boat Knives | Rigging & Safety Knife | Utility Blade
There isn't a device on this world that can measure the indifference I have for that statement.
Yamsailor is offline
post #40 of 119 Old 03-15-2012
Oddly enough I had a coupe of extra small good Solingen steel kitchen knives, so I made a small belt sheath for a paring knife, drilled a hole in the handle for an elastic wrist lanyard, and that's my sailing knife. Use in the galley is forbidden because I keep the blade mercilessly sharp. Works with one hand, either hand, and holds an edge that will part any taut line without pushing on it at all.
And it was "free", just had to take it out of the draw.
Of course in a true emergency, I could always dine with it.
RichH likes this.
hellosailor is offline
Duluth to Knife River shanedennis Lake Superior 30 06-12-2013 09:59 PM
Boat pocket knife rikhall General Discussion (sailing related) 39 09-03-2011 08:12 PM
Spring-Assisted Knife - what is your experience ? rockDAWG General Discussion (sailing related) 38 07-21-2010 06:58 PM
Sailing / Rigging Knife kiyoshi147 Gear & Maintenance 18 10-19-2008 03:18 AM
Knife question Songlines82 Gear & Maintenance 10 08-18-2006 11:11 PM
