12volt charge - Page 2 - SailNet Community
post #11 of 12 Old 03-22-2012
travlin-easy's Avatar
Re: 12volt charge
Originally Posted by grandcapri View Post
Northern tools has 15 w panels in sale for $69... I picked up a couple if those... Nor sure if it's cheap quality, but the price is right. Thanks for the tip.
Those panels will work just fine, but you must use the controller in conjunction with them to prevent overcharging of the batteries. You can buy the controller at West Marine for $30 SUNFORCE Seven-Amp Solar Charge Controller at West Marine
As for the panel sending spikes to delicate electronic gear, it's darned near impossible if the panel is properly wired and a controller is used. Keep in mind the panel is wired directly to the batteries through the controller, while your electronics is wired through the electrical circuit breaker panel. Consequently, when the battery switch is turned to the off position, the circuit breaker panel is disabled, but the batteries will continue to be charged by the solar panel through the controller. The controller regulates both the voltage and current that goes to the batteries ONLY--not what the batteries are sending to the circuit breaker panel.
Good Luck,
Gary
travlin-easy is offline
post #12 of 12 Old 03-22-2012 Thread Starter
grandcapri's Avatar
12volt charge
Sorry for the typos.. This iPhone is killing my writing skills...
grandcapri is offline
Honda Gen won't charge Crepard Electrical Systems 20 07-31-2011 06:30 PM
Gel Batteries: How to charge them ukrsindicat Electrical Systems 8 11-18-2010 10:00 PM
To charge or not to charge lyonsian Gear & Maintenance 27 05-13-2007 07:11 PM
Charge regulators Newport41 Gear & Maintenance 2 01-24-2007 04:05 PM
Slightly OT (maybe) - Best Hammock / 12volt Blender ? - Xmass Gifts :) labatt General Discussion (sailing related) 24 12-11-2006 02:14 PM
