12volt charge - SailNet Community
post #1 of 12 Old 03-20-2012 Thread Starter
grandcapri's Avatar
12volt charge
Before I blow up my elecrtical system, would someone tell me if I can charge my twin bank batteries on my sail boat using the 12 volt outlet, as with regular car charging?... I desire to plug in a solar panel and it's the easiest access point. Also, "all" battery switch should be selected?, I do have a controller.
grandcapri is offline
post #2 of 12 Old 03-20-2012 Thread Starter
grandcapri's Avatar
12volt charge
Anyone?
post #3 of 12 Old 03-20-2012
travlin-easy's Avatar
Re: 12volt charge
It will work just fine, as long as you have a solar panel regulator. That cigarette lighter adapter plug is nothing more than an extension cord to your batteries--nothing more. The battery switch should be on ALL for it to charge all the batteries at the same time, but if you only have two batteries in the boat and a battery switch that is 1, 2, All, I would recommend just charging one battery at a time--just to be on the safe side.
Hope this helps,
Gary
travlin-easy is online now
post #4 of 12 Old 03-20-2012 Thread Starter
grandcapri's Avatar
12volt charge
Thank you, very helpful. I'm trying to become less dependent and solar power is my 1st step.
post #5 of 12 Old 03-20-2012
Re: 12volt charge
I use a single, 15-watt solar panel to keep 4-golf cart and 1-deep cycle marine battery charged. I check them every week with a hydrometer and they're in perfect condition. Some of the golf cart batteries are 6 years old and still working just fine.
Gary
post #6 of 12 Old 03-20-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: 12volt charge
Using the cig lighter outlet is fine; as Gary says, it's just a connection to your battery.
One good reason not to set the selector to 'All' is if one batt has been drained and the other is topped up. When connected together, current will flow from the 'good' batt to the 'bad' one with no regulation. I'm not an expert, but I'd make sure they are within half a volt of each other, before you connect them. If it were me, I'd charge one batt one week and then the other for the next week and never connect them. I would only use 'All' if both batts are weak and you think together they might have enough juice to start the engine.
Imagine if you set the switch to 'All' and some fault in the system killed both batts while you're away.
Again, I'm not an expert.
When I set up my charger, I hook it right to the battery and leave the panel off. This eliminates any 'vampire' loads (like the panel 'ON' light) and reduces the risk of a fault draining the batt (and ruining it if you don't catch it in time).
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #7 of 12 Old 03-21-2012 Thread Starter
grandcapri's Avatar
12volt charge
Some very good information, I'll put it to use...
...any thoughts on adequate inverter size to keep on board?, charge/run basic items.. VHF, phone, gps, maybe small fan on the hook..
post #8 of 12 Old 03-21-2012
Re: 12volt charge
The VHF, GPS and cellular telephone will all run on 12-volts DC. I have a 70-watt inverter on the boat that runs a 21-inch flat screen TV and the laptop computer. I also have a 150-watt inverter that is used for my wife's IPPB breathing machine.
Cheers,
Gary
post #9 of 12 Old 03-21-2012
Re: 12volt charge
If you have a cheap solar panel like the small piece of junk I got a Harbor Freight and returned which puts out unregulated 24v, you could blow something out if you turn the battery switch off disconnecting the battery and some low power device like a depth sounder is connected to the circuit.
steel is offline
post #10 of 12 Old 03-22-2012 Thread Starter
grandcapri's Avatar
12volt charge
Northern tools has 15 w panels in sale for $69... I picked up a couple if those... Nor sure if it's cheap quality, but the price is right. Thanks for the tip.
Honda Gen won't charge Crepard Electrical Systems 20 07-31-2011 06:30 PM
Gel Batteries: How to charge them ukrsindicat Electrical Systems 8 11-18-2010 10:00 PM
To charge or not to charge lyonsian Gear & Maintenance 27 05-13-2007 07:11 PM
Charge regulators Newport41 Gear & Maintenance 2 01-24-2007 04:05 PM
Slightly OT (maybe) - Best Hammock / 12volt Blender ? - Xmass Gifts :) labatt General Discussion (sailing related) 24 12-11-2006 02:14 PM
