compression post repair/replace or addition ? - SailNet Community
post #1 of 2 Old 03-22-2012 Thread Starter
Hey Gents and Ladies,
Looking foreward to another great season on Lake Erie coming up ! Lots to do, and last year,
I noticed a wee dish on the deck around my deck stepped mast. She's an Ontario 28 with a partial bulkhead underneath and what looks like a 2 x 4 compression post in the corner. I know the mast, once snugged on (I make sure not to over tighten too much ), causes the deck to depress a bit . Now failing the obvious, does the deck have moisture issues, could I marry up another 2 x 4 to the one present ? I do not think there is any rot in the present post, it may have just shrunk 1/2 " or so ?
Any thought s are appreciated,
Mike.
GaiaOrion is offline
post #2 of 2 Old 03-22-2012
Senior Moment Member
SloopJonB's Avatar
Re: compression post repair/replace or addition ?
Any thought s are appreciated, Mike.
You probably have a core issue in your deck - wood doesn't shrink much longitudinally, certainly not 1/2" in 6' or less. Try a flexible batten across the camber of the deck at the mast step - see if there's a gap under it across the step area.
SloopJonB is offline
PSC 34 compression post cvsheppard Pacific Seacraft 13 04-13-2014 03:41 PM
Crack in the Compression post. mclerolw Boat Review and Purchase Forum 8 11-29-2011 03:28 PM
Need ideas for a new compression post SailingWebGuy Gear & Maintenance 12 10-23-2010 05:21 PM
Compression Post? SailOntario Gear & Maintenance 11 08-24-2006 10:03 AM
C&C25 compression post jimgre Gear & Maintenance 2 03-28-2001 08:03 AM
