Acoustic Insulation for engine room? - Page 3 - SailNet Community
 6Likes
post #21 of 31 Old 03-29-2013
Re: Acoustic Insulation for engine room?
Of course the problem with sheet lead is it still costs money. My reason for thinking of using Closed cell foam is that I already have it in 4x8 sheets, both 1" and 2". At the same time if it won't make any difference I won't waste my time but it seems to make sence that it would be better than nothing.
superiorvoyager is offline
post #22 of 31 Old 03-29-2013
Asleep at the wheel
jimgo's Avatar
So, would something like this have a max. temp. that's too low?
McMaster-Carr
At the recommendation of some of the guys on another forum I used to frequent, I used that on a car to help acoustically insulate the passenger compartment. I realize the inside of an inboard's engine compartment will likely get warmer than my old car, but I can't help but wonder if this might not help. I mean, the inside of the engine compartment is largely made of wood; what's the max. temp. there?
Just a thought...
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #23 of 31 Old 03-29-2013
Fresh water refugee
katsailor's Avatar
I am in the same situation, I am in the middle of a repowering project and asked the forum for input on lining the inside of my engine compartment to reduce the engine sound.
Here is a link to the thread http://http://www.sailnet.com/forums...100-paint.html
I am going to use 1 inch sound absorbing foam I purchased form McMaster Carr. I can not give good reference as to how good it works because I never heard the engine run before I bought the boat. All I can compare it to is how loud is with the engine compartment door open or closed and how loud the engines sound on similar boats. just my .02
The compartment was originally lined with foam that has deteriorated over the 30 years.
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #24 of 31 Old 03-29-2013
voyager, my understanding is that the closed cell foam, if it is high density, will stop high frequency noise, much as ear stopples will. If you've ever used these you may note the effectiveness differs greatly from one brand (foam type) to another.
If you want to stop low frequency noise, you do that by converting the energy into heat, and that requires mass. That's what lead sheeting is for. The high mass of lead absorbs large amounts of vibrational (acoustic) energy and converts it into heat. You can't do that with anything unless it is DENSE which is why they still use lead.
Physics rules, there's no other magic solution. There are some high density plastics like "sorbothane" and others but you will find them as pricey as lead. Bottom line, you can pay the piper, or listen to the the pipes.
Or get some of those expensive Bose active headphones.
hellosailor is offline
post #25 of 31 Old 03-30-2013
Senior Moment Member
SloopJonB's Avatar
I've seen a commercial lead/foam sheet that has a fairly dense black "polyfoam" type of foam with a sheet of lead sandwiched to it and a foil backing on the lead side. How does the group think this might work if you first lined your engine compartment with sheet lead then attached the foam product with the lead side "in" - this way you'd have the foam creating the dead air space between two skins of sheet lead.
It would cost several $hundred but the theory seems to fit well with the comments in this thread.
SloopJonB is offline
post #26 of 31 Old 03-30-2013
Fresh water refugee
katsailor's Avatar
Sounds like a trade off and a function of how much money do you want to spend, although I have noticed that my sound-proofing is entirely efficient when I shut off the motor.
post #27 of 31 Old 03-30-2013
Jon, I suspect the lead that is mounted against the engine compartment walls will still transmit some sound. You might try using "Dynamat" against the walls, that's what it is designed for. Not cheap but supposed to be effective.
post #28 of 31 Old 03-30-2013
Originally Posted by miatapaul View Post
By the way Dynamat is really just asphalt, so there are adhesive roofing materials that work the same, again really just the mass of the heavy coating. The stuff does smell pretty bad though. I have used it successfully in car installations.
What are we talking about specifically by "adhesive roofing material". do you mean the brush or roll on stuff you put over felt or use for roof repairs etc. If so I could just coat the plywood that encloses the engine compartment and then add foam to the outside to add "dead air space"
post #29 of 31 Old 03-31-2013
I installed soundown (salem ma) 25 yrs ago around the engine box on my Apache 37 when I replaced the gas engine with a Volvo diesel (much louder). Made huge difference...can hardly hear the engine running. The only disadvantage is the weight of the wall that has to be occasionally removed for winterization. But, a great solution. Hope that helps. Soundown - peace and quiet for architectural, marine, & industrial applications
Moe
T37Chef and jimgo like this.
mgiguere is offline
post #30 of 31 Old 03-31-2013
Flyby, Is that lead foil in the middle between TWO layers of foam? Can you make this up yourself in the engine room or does it have to be pre-manufactured sheet goods?
Sure if you have the lead foil and a good pressure sensitive adhesive that is compatible with the foam you use.
The really good high end foam is rubber.
Dick
Flybyknight is offline
Engine Room Sound Insulation Beersmith Gear & Maintenance 3 08-04-2011 04:21 PM
Engine Room Insulation eharan Gear & Maintenance 4 10-26-2008 11:46 AM
Engine Insulation prussell Gear & Maintenance 10 03-24-2004 03:09 AM
Engine Room Insulation RichardElliott Gear & Maintenance 1 01-09-2004 02:00 PM
Engine Room Insulation robw_fl Gear & Maintenance 4 03-09-2003 04:47 AM
