Furling from the Tack first - SailNet Community
post #1 of 1 Old 03-24-2012 Thread Starter
Aac
Furlers furl a sail in a direction perpendicular to the forstay. As the sail furls the Luff length decreases. In order to furl a sail starting from the Tack the following is necessary:
- A foil
- A free spinning tack and head
- No luff grove, instead the Luff is attached around the foil with soft hanks.
The amount of sail furled at the clew relative to the head would be dependent on the tension in the halyard. Imagine the Luff being only present and represented by a rope. As the Tack is furled the Luff rope wraps around the foil.
Has any of the manufactures got anything like that working. The reason I ask is that it would be possible to furl and maintain Luff length. Thus it would be possible to turn a 130% Genoa into a properly sized 100% genoa. Also, as the tack is furled first the Clew is lowered which is desireable; ie. a high Clew Genoa ends being a low clewed jib.
I can see the engineering difficulties but it seems that it may be possible.
I know the difficulties associated with camber etc.. but this is not what's beign asked.
Aac is offline
Port tack faster than starboard tack, same point of sail? zAr Learning to Sail 28 09-06-2011 05:57 PM
Track-N-Tack RAdair89506 Gear & Maintenance 2 06-02-2007 12:16 PM
tack course agoodman Seamanship & Navigation 0 05-17-2005 05:15 AM
Pig to tack Dogsbody General Discussion (sailing related) 2 06-23-2003 08:12 AM
How do you tack a cutter? JeffC_ Seamanship & Navigation 7 02-22-2003 12:55 PM
